Showing 1 to 7 of 7 results
clayton
Thank you received: 25
Hi anyone got an easy way to remove the rear tire off from the hub assembly? I removed all the nuts/clamps and smacked the back with a sledge hammer with no luck so then I put my backhoe blade on the backside thinking I could jar it off but no luck. Am I missing something or are they just that difficult to remove?
Mon, Jun 15, 2026 12:18 AM
Online
Thank you received: 93
Hi Clayton,
they are usually a mongrel to remove due to the tapered seating between the rim and hub--picture a full circle spider type hub on a truck.
Maybe make up a tooling using a hyd. or a screw jack and apply separation force from the opposite side rim/hub after refitting loosely, a few clamps and nuts, to stop the wheel flying off and damaging something or more importantly someone.
Hope this helps.
Mon, Jun 15, 2026 1:17 AM
Thank you received: 140
Hi, Clayton.
LOTTTTZA 'loose juice' and probably a fair bitta patience, maybe the occasional cuss word too. If you still have the original drawbar in place and itza rear wheel on the tandem, a porta power might help. For a front tandem wheel, you might be able to set up a porta power between the main frame and the rim - might be able to do that with the rear tandem too if you jack up the front of the tandem case a little.
Off the top of my head, I can't think of how you might use a porta power onna front wheel.
Mon, Jun 15, 2026 3:07 AM
clayton
Well I had some success today got a decent workout lol!
Wed, Jun 17, 2026 12:41 AM
clayton
Wed, Jun 17, 2026 12:42 AM
Hi, clayton.
Congratulations.
Just my 0.02
Wed, Jun 17, 2026 3:28 AM
Mark Riendeau
Thank you received: 34
Side note. There's a contractor here that has a 212 with a manual (winch) operated wing plow made by OmhSteel. The miniature size of the machine and snow wing is interesting.
Wed, Jun 17, 2026 5:42 PM
Online
Well done on leaving the rim mounted and simply? removing the tired tyre from same.
Thu, Jun 18, 2026 1:13 AM
