1J 22
Showing 1 to 10 of 16 results
WayneRKing
Send a private message to WayneRKing
Hi Greetings from South Africa. I am busy restoring an 22 what is the acceptable oil pressure? I am getting 15 psi on a master guage
Mon, Dec 13, 2021 12:02 PM
brewzer
15 psi will work just fine.
Mon, Dec 13, 2021 1:27 PM
Thank you received: 76
Reply to brewzer:
Hi Wayne, what Wally said. The 22 is a great tractor. My cousin's 22 takes quite a while to start registering pressure. The big ends and mains are quite worn but I understand there is a high volume of flow to make up for loose tolerances. In any case, it never gets more than a third up the gauge. What items need work done to them?
Mon, Dec 13, 2021 8:33 PM
GrantJ
Thank you received: 10
My earlier 22, a 2F in the first thousand built runs at 25 lbs for a while and drops to 15 when warmed up. At hot idle it drops to 8 or 10 psi and I dont worry about that at all. Grant.
Mon, Dec 13, 2021 10:50 PM
Thank you received: 92
Hi Team,
scan below tells what the gents above spoke of right from the Big Yellow Father.
Tue, Dec 14, 2021 9:30 AM
WayneRKing
Reply to edb:
Hi Team,
Thanks guys for the replies.I have noticed a lt of oil coming from the rocker adjusting screws . I found it many years ago with a stuck engine. I had new rings made and had the blocks re sleeved and crank ground. New head gaskets from cat.
I do have both parts and workshop book but getting spares is not easy. Our Caterpillar agent ( Barlows) very slow just to confirm the part availability then the cost is close to the gold price
Tue, Dec 14, 2021 12:03 PM
GrantJ
Reply to GrantJ:
I have a somewhat related question. My aftermarket oil gauge works fine but I cant find a water temperature gauge that fits the opening. The old ruined one had a brazed up adaptor and I have not found the right combination to fit a modern (inexpensive) gauge. Any suggestions???? Grant.
Tue, Dec 14, 2021 10:12 PM
Reply to GrantJ:
I was going to try my hand at soldering a new bulb from the auto store on to an old gauge face. Someone on the internet did it and apparently it worked well. The reading might have been off a bit but you can adjust it when sitting the bulb in boiling water
Wed, Dec 15, 2021 6:14 AM
Hi Team,
have posted this many times before so hope it helps--Google is your friend to find these articles, sort thru them to find the best one for your needs.
https://www.ply33.com/Repair/tempgauge
Wed, Dec 15, 2021 6:28 AM
brewzer
Reply to GrantJ:
I have a modern SW gauge on my 22. It is a wings edition and cost about $70 at the parts store. You also have to buy an adapter for the bulb to fit the 22. I will post the numbers tomorrow of the gauge and adapter. If you want the original look I have some broken original gauges that you can work on.
Wally
Wed, Dec 15, 2021 12:34 PM
Reply to brewzer:
Wally
I have one of Wally's broken original gauges that I intend to repair using Eddie's link. Just need to get around to it : ). The 5U's track frames are what's on the front burner currently
Wed, Dec 15, 2021 8:32 PM
