1966 D7E blade pins
1966 D7E blade pins
Showing 1 to 10 of 15 results
zbrown78
Send a private message to zbrown78
Hello all -- newbie to the site and loving all of the great information!
I just purchased a D7E serial# 48A7052 and I'm having the seller break the blade down for easier transport. They have all other pins removed but they are having a hard time with the 4 lower pins(2 on each side) that attach the side arms to the back of the blade. Any guidance on whether they're just stuck and stubborn or do they have to came out in a certain order/direction? They said they worked with it for a while and couldn't figure it out. They're not a CAT shop with all of the knowledge, just private sellers.
Thanks in advance for any help, Zane
[attachment=30239]IMG_0586.JPG.jpg[/attachment]
Thu, Jul 23, 2015 11:29 PM
Digitty1
Send a private message to Digitty1
IT'S A YOKE STYLE connection. If they get ethier pin out , the arm will come off. Pins are rusted in the blocks. May have to cut one on each side to get it apart.
Fri, Jul 24, 2015 3:18 AM
zbrown78
Reply to Digitty1:
Thanks for the input. You know a dumb question is in order 😊 Asside from flipping a coin, any experience on which one comes out easier without a hot wrench? Thanks, Zane
Fri, Jul 24, 2015 3:24 AM
Thank you received: 19
Reply to zbrown78:
As those pins wear they wind up with offset and mushroomed/stepped shoulders. The top pin is probably rusted in but that's not likely on the horizontal pin. If you have to burn one out I'd say it would be the horizontal one that you can tackle from both ends.
Fri, Jul 24, 2015 4:36 AM
zbrown78
Just in case it helps someone in the future, I'll post back with the outcome. Thanks, Zane
Fri, Jul 24, 2015 4:45 AM
Reply to zbrown78:
Might be able to put a hyd ram on the pin closest to the blade. Put it between the top brace socket and the pin.
Gary
Fri, Jul 24, 2015 8:10 AM
zbrown78
Gary
Just heard from the seller. They have a son who's a CAT Mech. He brought over a 30T press to help them out. They said the pressure dial was max'd out and they still had to convince the pins with an 18# sledge. Thanks for the feedback guys. I guess I'll be making the drive to pick up the blade now.
Zane
Tue, Aug 4, 2015 8:42 PM
JoeG
Send a private message to JoeG
Reply to zbrown78:
Zane
Where you from Zane? I just bought a D7E this spring. Hauled mine with the Angle blade on just angled and away we went. You gotta post pictures of it when you get a chance.
Wed, Aug 5, 2015 7:57 AM
zbrown78
Reply to JoeG:
I'm in Georgia JoeG. The whole reason for the pin question is because the dozer came with 2 bladed; a 7S and a Chicot V. Apparently, hauling both blades on the same trailer would make too much sense. So, because of the transport laws, it could only be one or the other. FYI, if you have the option, ALWAYS drive AROUND Alabama! Since the V blade is much heavier and cumbersome, I had the seller put the V on the tractor so it could go by semi. I am going to drive to Arkansas and pick up the straight blade with our trailer but need it to be more compact.
Here's a pic. It's got a few superficial blemishes and I've got the heads off right now for rebuild. But, it was the right price and should be in good working order once I'm done lovin' on it. I bought it because it was a one-owner and many parts have been rebuilt/replaced already. i.e. Radiator, turbo, oil coolers, magneto, rollers. It's easily worth more for parts than I have in it right now. Let's hope it stays that way!
Thanks, Zane
[attachment=30429]D7E_Arrival.jpg[/attachment]
Thu, Aug 6, 2015 8:31 PM
Reply to zbrown78:
Thanks, Zane
Did that use to be a Pine Plantation Stump tractor where they harvest the stumps for the pitch to make turpentine?
Fri, Aug 7, 2015 4:08 AM
mrsmackpaul
Reply to drujinin:
dunno much about that blade have never seen one before is it for making ditches or chopping trees down ????
Paul
Fri, Aug 7, 2015 5:23 AM
