1948 d6 9u magneto
1948 d6 9u magneto
m10878
Send a private message to m10878
having problems with the magneto just put new points and condensor and it started fine, than we rebuild the clutch just got it put back togethor the other day and now were not getting a spark again. any ideas on how to fix the problem or even another form of distributor that might work instaed of the magneto was thinking maybe off a motorcycle.
any help is useful
Mon, Jan 4, 2010 12:55 PM
bruce oz
Thank you received: 20
hello m10878 ,did the mag spark of the tractor ? ,if it did, try it without the kill switch disconnected ,kill switch can get moister inside them or corrosion in them causing a short .bruce oz
Mon, Jan 4, 2010 1:03 PM
m10878
Reply to bruce oz:
actually tried that yesterday started off as it wasnt getting much of a spark than it started sparking in the wrong place. it started sparking off the spring instead of the points which i didnt understand. messed with it alittle a few mins ago managed to loose 2 of the screws trying to put the points back on with just a drop light have to start again tomorow. im thinking i might have to replace the points again.
Mon, Jan 4, 2010 2:01 PM
Thank you received: 19
Reply to m10878:
With new points and condenser and the run test you should be good to go. Do a cleaning of the points as oxidizing of the contacts is the most common reason for no go. You can check for actual continuity across closed points if you lift the wire that goes to the upper LH corner of the mag. If that doesn't get it you must have the point spring grounded somewhere to see arcing there.
Tue, Jan 5, 2010 3:02 AM
