171 Hydraulic Control??
greengiant
Send a private message to greengiant
What is a 171 Hydraulic Control and how do I tell if my D7E has it? The transmission oil drain procedure is different for ones with and without. The one with it has 3 more gallons of oil.
Thanks!
Sat, Aug 12, 2023 9:19 AM
Thank you received: 63
The 171 Hydraulic Control consists of a fender mounted external (foot operated) control valve and a hydraulic pump. The control is used to operate a hydraulic blade tilt cylinder. The vane pump is mounted on the rear power take-off housing of the engine and is driven by the rear power take-off idler gear. The oil for the hydraulic control system is supplied from the tractor transmission and is cooled and filtered by the transmission oil system.
Sat, Aug 12, 2023 11:26 AM
seiscat
Go to the library and look at the D7E 16 page brochure I just put there yesterday. It has pictures of the all the hydraulic systems available for your tractor.
Craig
Sat, Aug 12, 2023 7:37 PM
greengiant
Reply to seiscat:
Craig
thanks guys! mine is a 173. i had drained all the oil that i could find plugs for and then it occurred to me that if mine is a 171 i should have drained the hydraulic with the motor running first.
Sun, Aug 13, 2023 1:12 AM
