Tractor Parts
Tractor Parts
CrawlerAddict
While searching the web I came across FP Smith tractor parts.They seem to be a valuable resource for old machinery.
http://www.fpsmitheq.com/vintage.html
CrawlerAddict
Mon, Feb 10, 2025 9:07 PM
B2dbmfuder@2007
Send a private message to B2dbmfuder@2007
I will be posting a link for eBay for d2 and d4 pony motor replacement piston rings. The are not cat parts but work. The rings are a chrome composition for compression . They fit standard pistons and there is a plus . 010 set for slightly worn standard bores.
The are compression and oil for both standard and plus . 010. The seller is in the process of setting up a link for the cat part numbers. He worked with me when nobody else would.
The parts are not for the intended application, but work and fit. I will keep you posted.
Tue, Feb 18, 2025 1:13 AM
B2dbmfuder@2007
Reply to B2dbmfuder@2007:
And no I will not make a dime, just sharing because I hate when i was told to junk it, pony motor.
Tue, Feb 18, 2025 1:15 AM
B2dbmfuder@2007
As promised cat rings for the pony motor d2 and d4. Standard to plus .030. compression and oil.
I have used these and the work and fit properly. I make no money on this. Looking for bearings for the rods now. I can make my own crank bearings . If anyone know where i can get standards. Cat quit selling the standard bearings.
https://www.ebay.com/itm/176873277748
https://www.ebay.com/itm/176873302396
https://www.ebay.com/itm/405579382998
Wed, Feb 26, 2025 3:04 AM
| Hartley - South Australia
Newby Hall Tractor Fest
