$40 /year ELECTRONIC
$55 /year USA
$67 /year International
pony to electric start - new parts source
11 years 3 months ago #32577 by Old Magnet
Hi n7gxs,
I'm a little slow on the uptake here but just realized the glow plug chambers use a different injector retaining nut and seal The nut is a 8F8061 and the seal is a 5B3718. The nut takes a special splined socket part # 8S2243.
I believe that will explain the problem with clamping the injector nozzle using the standard chamber parts.
11 years 3 months ago #32598 by n7gxz
I took out about .200" out of the top of threads and everything now fits. Just waiting for the glow plugs to arrive.
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
11 years 3 months ago #32601 by n7gxz
OK the glow plugs showed up today. Now I need to decide how to connect the wires. The terminal end is a .25" smooth shaft. I can thread it and put a couple of nuts on it and then use an eye terminal on the wire.
Kevin
11 years 3 months ago #32627 by Old Magnet
The original Cat system used a 9F8584 sleeve and 9F8585 collet as part of the glow plug lead assembly. I have no idea if they are still available or not. Never tried threading....don't know if you can do that without cutting through the very thin jackets. I'd try to come up with some type of socket plug in system.
11 years 3 months ago #32709 by n7gxz
Well I think I've found what I can use for the connectors to the 3H2033 glow plugs. I had a set of old spark plug wires and the cap end fits on the glow plug end real nice so I'm going to try and build up a set of glow plug wires with them.
Kevin
11 years 1 month ago #33992 by BOWTIEIH
Replied by BOWTIEIH on topic 955 12a
Thanks for all the help, I got the starter put on this weekend and she fired up. Now to get a 12 volt alt put on her and we will have everything finished. It is so nice to turn a key and have it start. verses having to toy with the pony. When I pulled the pony I made plate to cover where the pony set and put a 1/2 inch nipple in it, hooked that up to a block heater, sent that to the head. So if I need the old girl this winter we should be ready to roll. After shopping around I ended up with 350.00 in the starter.
Thanks once again.
11 years 1 month ago #34005 by jaker65
sounds like you did some nice work there. If you could, i would like to see how you hooked up the block heater. if you could, post some pics. i know a great deal of us would like to see this. anyways, hope all works out for you! have fun playing with your toy :D
11 years 1 month ago #34215 by BOWTIEIH
I Will Get Pictures Of It All Put Together
11 years 1 month ago #34217 by bcwayne
Heres a picture of another method that I used of connecting a block heater as recommended by other ACMOC members... I bought a 1500 watt KAT brand heater from Amazon.com..... works great.:)
10 years 8 months ago #41915 by 3TRob
Replied by 3TRob on topic Source for conversion kits
CME in Florida advertises in Rock & Dirt that they handle all conversions from pony to electric start for Cat machines.
PHONE (305) 633-1524 • FAX (305) 633-9537
