#44 Hyd Pump input shaft seal replacement?
11 years 5 months ago #88114 by randy merrick
Trying to replace the seals around the drive shaft on my #44 hyd pump ser #6W12536. I have the unit off and have also pulled the pump from the unit. I have a copy of the page from a parts book showing the parts detail so at least I can see what they look like
My question is can the "Retainer" part #4F3964, which appears to hold the seal, be removed by just taking out the 4 cap screws? Or do I have to dismantle the whole pump?
I have tapped on it with a chisel to try and get it free and then I tapped a little harder. It does not seem to have budged at all. The pump seems fine so I would rather not take it all to pieces if I do not have to.
Thanks for any advice, randy
11 years 5 months ago #88116 by josh
The retainer can be pretty snug in there, but will come out without taking the rest apart, may take some soaking and lots of tapping with a brass drift or plastic mallet, but should come free, just don't bust it, you might make a small hook type, slide hammer puller and hook the edge near the shaft, once it is a little loose.
11 years 5 months ago #88118 by randy merrick
Thanks for that detail. Did not want to keep trying only to find out that that was something holding it from behind.
Will persevere.
randy
11 years 5 months ago #88119 by randy merrick
oops I just realized I was on the for sale section and not discussion when I post this, sorry, randy
