try :
Jim Zimmerman
Orchard,Iowa (641)982-4207
Old CAT parts and cats
for a 2nd hand part
or if you have a normal / original size ball bearing can you not tig weld it in the old casing or brass weld it in? saves you a lot of money.
Hi Janmeermans,
my old books tell me that the 1B4099 is also a New Departure Bearing 20209
I do not think a roller bearing is suitable for the clutch release application due to the side loadings. (I stand to be corrected)
As MARCOTEN suggests if you cannot get a bearing of the correct dimensions you could sleeve or weld up and machine to size your release housing.
