D4 7U fan--pusher vs. puller
D46UClint
Send a private message to D46UClint
Now that the D4 7U is home (thanks to the board for all the help) I've been crawling all over it checking out its scars and imaganing its life history. I noticed last night that the fan is a pusher not a puller like was on my 6U with a straight blade. Since this old gal has the toolbar setup I'm not surprised given the Ag work it was intened for. How common are the pusher fans on the U series machines?
Wed, Jul 25, 2012 10:41 PM
Pusher fans are a fairly common option, especially on dozers. Helps considerably with controlling dust but they do tend to be a little harder on radiators due to abrasion in heavy dust situations.
Wed, Jul 25, 2012 11:31 PM
rjh-md
Pusher fans on6U & 7U,s not common ,I have 4,D-6u&7u ,s ,all have puller fans
Actually pusher fans are more efficent to draw heat away from the engine.
I am wondewring if you have a high ser# abouve 29000 where Cat added the option ?
Wed, Jul 25, 2012 11:33 PM
Old_n_slo
Send a private message to Old_n_slo
Reply to rjh-md:
Huh?
Efficient heat transfer relies on cooler air moving past a heated object (radiator). How does heated air from a hot engine going through a radiator promote better cooling? I'm not being critical, just want to know.
Thu, Jul 26, 2012 1:29 AM
catsilver
Reply to Old_n_slo:
Huh?
Which is best, drawing cool air over the engine to go through the radiator, or pushing already warm air back over the engine to waft back over the operator? I'm told that pusher fans were introduced to stop drawing dust and dirt from the blade back into the radiator, but I reckon it was mainly to stop blowing dust back over the operator.
Thu, Jul 26, 2012 2:20 AM
8C 361
Reply to catsilver:
My '50 HT4 has a stock pusher fan. I put a pusher on my 7 U, she is a downhill puker. That way all that puke doesnt get in the fins and turn the dust into mud.
Thu, Jul 26, 2012 3:27 PM
D46UClint
Reply to 8C 361:
i have it written down in the truck but working off memory (bad idea) her badge says she's #7U22230 I believe. The D315 wears a different number 22207 and also has a tag from "Kersaw - Wheeler" in Salt Lake City Utah with an overhaul date of 1956!! Tag states bore, mains and rods are all standard as is the pony. I'll have to pull the exact S/N off the 315 to verify it's original application.
I find it really interesting trying to sort out the life history of things. Maybe she ran low on oil and spun a main/rod, maybe over heated trying to keep up with D6, maybe rod cap let go.......
I restored a mahogany Chris Craft 10 years ago and the boards and frames still had the pencil marks, signatures and "shop math" written on them. I'm very nastaligic and think this kind stuff is really cool.
Thu, Jul 26, 2012 8:10 PM
rjh-md
Reply to D46UClint:
I figered your D 4 was a high ser # ,To have a pusher fan on it .
As for fan types , I f you were driving down the road ,and air was actually being forced in the raditor ,and past the engine ,a puller fan is more efficent .
Crawer fan use is different ,the air is static ,and only moved by the fan on both sides of the raditor . A puller fan is drawing warm air through the raditor,heating this air ,and blowing it on the engine .A pusher fan is drawing cooler air past the engine and though raditor and dirverting it away from the tractor .
Cat has always maintained that pusher fans were more efficent . All the later track loaders,and crawer tractors either have pusher or reversable fans on them to push hot air and dirt away from the engine and raditor .
Reversable fans are the best fan ,so that in warm weather the fan can be a pusher ,and in cold weather the fan can be turned to warm the tractor and operator.
Try sitting on a D6,7, 8 9 in the summer with a puller fan blowing hot air,and dirt back at you and see how long it takes to get out the fan reversing tool to reverse that fan to a pusher !
Thu, Jul 26, 2012 10:07 PM
Reply to rjh-md:
I have a Huber reversable fan on my 7U. when I would farm with it I had the fan blowing back the tractor ran allot cooler but when dozing I would have it blowing foward. Now thanks to the cushy ac cabs everyone wants Huber is no longer in business.
Fri, Jul 27, 2012 7:26 AM
