D2 dash hack?
D2 dash hack?
Showing 1 to 10 of 11 results
Old_n_slo
Send a private message to Old_n_slo
I just might be removing the dash for some other work, and always wondered about this left side dash hack from a prior owner. The first thought was to gain access to the pony behind it, but there is nothing gained that I saw by opening this up.
Thoughts on why this opening was attempted, but abandoned? Hey, even funny answers get you credit.
Sat, Jul 7, 2012 6:34 AM
zootownjeepguy
Hate to burst your bubble, but right behind that butcher job is where the Pony Blocks usually crack from freezing.
Things could get uglier once you pull the dash out.:jaw:
Rich Salvaggio
D2 5U9917
Sat, Jul 7, 2012 6:44 AM
Oil Slick
Reply to zootownjeepguy:
It's been said many times "if only the previous owner took a little more pride...."
At least it looks like an easy repair.
Sat, Jul 7, 2012 7:31 AM
lil cat mec
Send a private message to lil cat mec
Reply to Oil Slick:
was it brought back from mexico??? maybe even drug dealers own cats lol😊
1935 CAT 22 2f4455W
CAT 951
Sat, Jul 7, 2012 9:07 AM
Old_n_slo
Reply to lil cat mec:
...that section does not appear to be bent down, then back up again. No sign of metal fatigue on the hinge area. I'll chalk it up to an exploratory dig for a spot to install a Jensen in-dash 8 track power supply. Stranger things have occurred.
I was able to remove the fender (hacked up, see my wanted post for some D2 fenders) and...THANNNNKFULLLY...removed the remains of a twisted off bolt head which happened on my watch. It holds down the foot rests. You know how junk drifts down there and brews to a fine rust enhancing consistency. A combination of good luck (and penetrating oil, heat, hammer blows, heat, more penetrating oil, blah, blah) resulted in.... Success!
Oh...and the head came off, the whole purpose of this project. Those cooling jackets are nicely preserved. All fresh water came out. I'll poke around a bit, but looks like a clean bill of health for the pony heads cooling passages.
Frosty beverage time!
Sat, Jul 7, 2012 9:27 AM
It appears to be right over the pinion latch adjustment plate. Perhaps it was cut to get a better angle for tools to adjust the latch. I have tried repeatedly to adjust mine but no luck so far with the firewall in the way.
Sat, Jul 7, 2012 9:31 AM
jbernd56
Reply to dpendzic:
I do like the idea about mounting a tape player though. The water passages do look good! In the second picture, the little bitty hole in the bottom right is the one that gave me fits on the D4. It had what looked like soot packed in there tight. Soaked it with citric acid and used a small twist drill and finally got water to go through. Good luck on the mystery flap!
Sat, Jul 7, 2012 10:07 AM
mog5858
Reply to jbernd56:
i too have 2 dash's with the same sized hole in them. my pony motor have bean weld up but would people really hack up just so they don't have to take out 1/2 a dozen bolts.mabey they did not have fath in there weld and need quick access.
Sun, Jul 8, 2012 12:22 PM
Kelly
Reply to mog5858:
Yes, some people do. I once worked around a crusher that looked like a patch made quilt.
Kelly
Sun, Jul 8, 2012 10:29 PM
D4guy
Send a private message to D4guy
Reply to jbernd56:
Speaking of dash hacks, here is mine. I guess the hole was cut to make a starter belt change. The first photo shows the flame-thrower cut after I cleaned it up a bit with the angle grinder. It was pretty horrible . I clamped a piece of 16 ga to the raised section as a form then heated it and hammered it down to make a similar shape. After trimming it and fitting it with a couple of 1/4-20 cap screws it covers the hack. It is not the best piece of workmanship, but after all it is just a tractor and I have a lot of other more important work to do on it. (The photos got posted in reverse order).
1955 D4 Traxcavator, 1926 Model T Roadster, 1930 Model A Tudor, 1940 Diamond T 201, 1954 JD 40 dozer
www.mervbergman.net
Tue, Jul 17, 2012 8:09 PM
Old_n_slo
Reply to D4guy:
D4guy, now that is a proper pirate eye patch! At least yours got paint after the repair. Right now I have just been primering after my patch jobs. I'm not sure of just matching the newer CAT color on my machine, or start with the correct yellow.
Well, I have had the dash off for a couple weeks, and got sidetracked making a newfangled MIG cart for my newfound joy of MIG welding. I took the torch to the dash and before I could say Constantinople, I had the weld bead ground down and its ready for sanding and primer.
No evidence of head damage behind the dash, its still a mystery why this project was abandoned.
I'm pretty sure I have pulled all the parts off that I need to (fenders, seat tank, dash) and now can begin putting it back together so I can fire it up and flush the cooling system and use it to manhandle my other crawlers.
Fri, Oct 19, 2012 6:37 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
