9U and 60 scraper pictures and cable questions
Showing 1 to 10 of 13 results
D8PETE
Send a private message to D8PETE
Well its been a long road but I finally got all the planets to align themselves. After a few years of searching for a 25 CCU, rebuilding it, finding tires for the scraper and changing them out, and then attending to a bunch of "little issues" on the D6, today I finally got them all hitched up and working together.
[attachment=13514]Cat D6 and 60 003.jpg[/attachment][attachment=13513]Cat D6 and 60 002.jpg[/attachment][attachment=13512]Cat D6 and 60 001.jpg[/attachment]
Everything worked well but I need to tighten up the spring to hold the bowl up when its loaded.👍
My question is for a 1D 60 scraper what size cable and how much is required to restring it, and how much "extra" cable should I leave on the spools? Thanks.
Pete
Mon, Jun 25, 2012 7:15 AM
hiwide15
Send a private message to hiwide15
Pete. I ran the d7 and the seventy pan all weekend. Striped 25 load of top soil anb then hauled 46 load of fill in an ald roadway then used the 9u to lay on the top soil got it all done in two days and it looks great. Good luck with the adjst on the ccu, Ron
Mon, Jun 25, 2012 7:26 AM
D8PETE
Reply to hiwide15:
Thanks Ron - Sounds like you've done pretty well yourself. With all the nice weather lately it sure makes it nice to move dirt and get work done! Just wish there were more hours in a day and I had enough energy to last them all.
Mon, Jun 25, 2012 8:02 AM
Reply to D8PETE:
Looks great!!! and fun to.
Cable requirements:
Ejection cable 1/2" size......75 feet
Bowl lift 1/2" size.....60 feet
Apron lift 9/16" size......18 feet
Spare cable on reel.....probably want enough to restring a couple of times.
Mon, Jun 25, 2012 8:25 AM
D8PETE
Cable requirements:
Thanks O.M.
Mon, Jun 25, 2012 8:40 AM
josh
Reply to D8PETE:
Thanks O.M.
3F8522,-cable and reel assembly, (cable control to rear cable reel) is 300' of 1/2" cable.
Mon, Jun 25, 2012 9:04 AM
Online
Thank you received: 34
Reply to josh:
Hi, Old Magnet.
Please correct me if I am wrong but I think Cat used 1/2" cable on ALL of their CCU's, front and rear mounted, and all their cable controlled machines, didn't they?
Mon, Jun 25, 2012 4:05 PM
D8PETE
Hi, Old Magnet.
I forgot to ask one other thing. Does it matter what wire size/grouping/lay the cable is? As you all know there is several types of 1/2" cable.
Pete
Mon, Jun 25, 2012 5:38 PM
Jeff M.
Reply to D8PETE:
Pete
With your money look at the price get the best it will last longer.Make sure you don't pull it into.
Mon, Jun 25, 2012 5:55 PM
Reply to Jeff M.:
Cable spec. is 1/2", 6 x 19 filler wire, right Lang lay, independent wire rope center, preformed improved plow steel type.
With the exception of the apron lift cable on scrapers the entire line of equipment is designed for this particular cable for maximum efficiency, from the contour of the groove in the sheaves to the sheave size, sheave bearings and all working parts.
Mon, Jun 25, 2012 9:12 PM
D8PETE
Thanks once again O.M. In what publication does Cat spec out cable types and where they should be used. I have never seen a spec in any of my parts, service, operators, etc. manuals. Just curious.
Tue, Jun 26, 2012 3:28 AM
