No. 6 Cat track loader
Showing 1 to 6 of 6 results
BullDozerBob
Send a private message to BullDozerBob
Can't seem to find much on the internet on the No. 6 loader. There is some info in the Cat books but I don't seem to find much on any survivors. I know it was one of the first Cat engineered loaders.
Anybody got any specs-pictures-engine model etc.
Thanks in advance.
BullDozerBob
Wed, Jun 6, 2012 9:44 PM
Hi Bob,
Your right, don't see much on the #6 shovel.
Here is what little I have and think I know....
#6 10A series built 1953-1955
Turned into the 977D (20A series) (1955-195😎 and then the 955E (1958-1960)
Used the D6 undercarriage and D318 engine.
I couldn't tell you what the difference between models is....all I have for the #6 is the Service Information manual.
Some specs on the 977:
Wed, Jun 6, 2012 10:41 PM
gemdozer
Thank you received: 7
Hi Bob,
The 6 loader is like a D6 and have a 318 motor and am still have a service information for NO-6 SHOVEL
Wed, Jun 6, 2012 11:23 PM
BullDozerBob
Reply to gemdozer:
Did Cat turbo it to get 100 HP? I know that Cat had a "grader/loader" kit for the D318. My D69U27222 had this kit added by the previous owner to save fuel/add horse power for field work. I only pull a 14 ft Goble 2ft diameter disk and it hardy grunts. Just Curious!
BullDozerBob
Thu, Jun 7, 2012 1:41 AM
Reply to BullDozerBob:
BullDozerBob
No turbo was used.
Early units 10A1-10A705 were less hp and rated at 1400rpm
10A706-10A1616 and the 20A's were rated at 1800 rpm along with a 9" dia. fan pulley, governor and spring changes and the 20A's got cam shaped pistons.
For comparison the 8/9U's were rated at 1600 rpm.
Thu, Jun 7, 2012 2:40 AM
David Wills Cat 60
No turbo was used.
Bull Dozer Bob
This is a photo of a No 6 Shovel owned by a collector in the UK.
Regards, David
1948 D6 9U
1963 D6B 44A
1970 951A 63K
1940's Le Tourneau S3 Rooter
Thu, Jun 7, 2012 4:19 AM
lil cat mec
Send a private message to lil cat mec
Reply to David Wills Cat 60:
Bull Dozer Bob
Regards, David
nice no.6 and vary nice DW10!!!
1935 CAT 22 2f4455W
CAT 951
Thu, Jun 7, 2012 6:26 AM
| Hartley - South Australia
