low engine temp.
low engine temp.
Showing 1 to 10 of 20 results
2island
Send a private message to 2island
I have a cat D6B 44A1. The engine temp. has always been low so I installed a new cat brand thermostat. It still runs cold, as the temp gauge is still in the white, and goes no higher. Any body have any suggestions
Mon, Apr 16, 2012 4:18 AM
Mike Meyer
The thermostat might be missing, or jammed open?
regards
Mike
Mon, Apr 16, 2012 4:20 AM
2island
Reply to Mike Meyer:
regards
Mike
thermostat is brand new. just installed
Mon, Apr 16, 2012 4:25 AM
Reply to 2island:
For that model the thermostat should be opening @ 175 deg. and full open @ 186 deg. F.
Minimum operating temperature should be above 160 deg. F.
Is the temperature indicator working correctly?
Mon, Apr 16, 2012 5:09 AM
2island
gauge is working. put sender in pan of water and heated
Mon, Apr 16, 2012 5:25 AM
Reply to 2island:
Hmmm, couple more then I'm done...
Is the thermostat properly seating in it's bore?
A certain amount of water bypasses the thermostat from head to water pump through a bypass line, does this appear corroded so that it has become oversize?
Mon, Apr 16, 2012 5:39 AM
2island
thermostat sits perfect in its bore and bypass hole is as clean as the day it was made
Mon, Apr 16, 2012 5:49 AM
Reply to 2island:
Do you know the history of the radiator core?....maybe replaced with a higher capacity heat transfer unit?
Mon, Apr 16, 2012 6:02 AM
Thank you received: 19
When you tested the gauge you took the water all the way to boil?Had a gauge that worked in the lower temperature range but stopped before the red.Had never seen one that worked at all that wouldn't read the whole range before this one.
If you don't us it a lot just us card board to block air flow to get the desired temperature.Good luck.
Ray
Mon, Apr 16, 2012 7:16 AM
catsilver
Reply to Ray54:
Ray
There is no way I would start trying to push up the temperature without knowing what it actually is, it could be at the correct temperature, gte hold of a thermometer or graduated gauge and check it out properly. There is probably nothing wrong.
Mon, Apr 16, 2012 7:16 PM
2island
Reply to catsilver:
once the blizzard stops, i an going to re test thermostat and gauge, is there just the one gaskit that sits on the head, then the thermostat , then the housing on top of the thermostat, like it was when i first took it apart?
Mon, Apr 16, 2012 8:16 PM
