CAT22 flywheel ring gear
Showing 1 to 10 of 47 results
I read in issue 96 of the acmoc mag that the flywheel ring gear from a Ford 390 motor will fit a CAT22 flywheel. From the CAT22 parts manual the ring gear, 2B914, has 118 teeth. That is what I have in my 22. When I check on the ring gear for a Ford 390 motor it has either 153 or 184 teeth, depending on year, and the diameter is wrong. Am I missing something here? Does anyone have knowledge of what the correct replacement ring gear is, and where to find one? Or does anyone have one to sell? Ray
Wed, Mar 28, 2012 5:47 AM
Willie
I was told long ao it was same as Ford Ranger PU
Wed, Mar 28, 2012 6:05 AM
Reply to Willie:
All of the Ranger flywheel ring gears I have located have the wrong diameters and wrong number of teeth.
Wed, Mar 28, 2012 8:28 AM
Jon
Send a private message to Jon
what is the inside and outside diameter of the ring gear? Jon
Wed, Mar 28, 2012 9:57 AM
Jon
What is the inside and outside diameter of the ring gear? Jon
Wed, Mar 28, 2012 10:12 AM
Reply to Jon:
Jon, I do not have calipers that large, but the approximate ID is 13 7/16" and the OD is 15"
I am leaving on a week's vacation and will be without computer access, so will check in with everyone when I get back in a week. Ray
Wed, Mar 28, 2012 5:11 PM
In an old Ford Model A repair book, it stated that the engine always stops between the same 2 cylinders that are 180 degrees apart. The cheap fix recommendation is to heat it, then rotate 90 degrees to an unworn section of the Ring Gear.
Also the poor-mans overhaul is to take the ring gear off and flip it over providing it has double bevel teeth.
Remember I am repeating what I read, not what I recommend!
Jeff
Wed, Mar 28, 2012 6:08 PM
Jon
Reply to drujinin:
Jeff
When you get back you can stare at this for a while.
http://www.ringgearindia.com/docs/products.asp
Fri, Mar 30, 2012 10:58 PM
lil cat mec
Send a private message to lil cat mec
Reply to Jon:
Jon- there are only 2 that even have 118 teeth and the in dia is 18.372/out dia is 19.880 or 19.885 so that will not help any...
1935 CAT 22 2f4455W
CAT 951
Sat, Mar 31, 2012 1:05 AM
Reply to lil cat mec:
Check the 80's model Ranger with the 2.9 liter (I think) V-6. Used to have one (long gone) in the family. Still have the manuals somewhere I'll see if I can find them but size and tooth count sounds about right.
Sat, Mar 31, 2012 2:19 AM
lil cat mec
the 80's ranger/bronco with the 2.9l has a flywheel ring gear with 138, i dont know the diameters but it is 20 teeth off!!!
1935 CAT 22 2f4455W
CAT 951
Sat, Mar 31, 2012 4:47 AM
