There is no spec for the clutch lever travel.....it's whatever it takes to get good snap over engagement with the clutch adjustment. Snap over force should be about 55 lbs pull measured at the base of the handle. Don't forget to follow up with transmission brake adjustment when adjusting the main clutch.
thanks for the replies
