Cat 10 motor grader
Cat 10 motor grader
Showing 1 to 6 of 6 results
gorton
Send a private message to gorton
In the late 60's, I worked with a Cat motor grader referred to as a model "10". It had a 4-cyl diesel engine, 10' moldboard, and tandem rear wheels. Operators called it a "kitty' because it was too small to be a Cat. I thought it was probably a 1950's vintage. I am wondering - was "10" the correct model, and is there any info on them?
Thu, Mar 15, 2012 4:51 AM
ianoz
Thu, Mar 15, 2012 5:01 AM
Thank you received: 39
Reply to ianoz:
Did it look like this ?
http://www.youtube.com/watch?v=81WiXuKL09w
Would be known as a "Diesel #10" s/n 2Kxxxx. Tandem drive built 1937 - 1939.
Thu, Mar 15, 2012 5:11 AM
gorton
Reply to ianoz:
[quote="ianoz"]Did it look like this ?
http://www.youtube.com/watch?v=81WiXuKL09w[/quote]
No, it looked just like a 12, just smaller.
Thu, Mar 15, 2012 5:35 AM
SpragueM
Reply to gorton:
The Model 112 is a smaller 12 with the 4 cyl diesel.
Matt
Thu, Mar 15, 2012 6:05 AM
Reply to SpragueM:
Matt
The "10" designation went away in 1940.
Then came the "12"
Shrink it some and you had the 112 (D4 engine)
Shrink it again and you had the 212 (D2 engine)
All 40's and 50's models.
Thu, Mar 15, 2012 6:36 AM
chriscokid
Then came the "12"
maybe this will help
http://www.chriscomachinery.com/Graders.htm
Thu, Mar 15, 2012 6:57 AM
