Reply to Muchbroker:
Thank you all -- I wil definetly check the clutch oil level, then try and dislodge the pinion. I really hope that is it.
Also thanks for the Ebay tip on manuals, I really got burned out on Ebay a few years ago due to the exorbanant (sp) costs of "shipping and handling" but I need the manuals so will just have to pay the piper.
Thanks again to all of you, I will be sure and post the outcome.
Muchbroker
Casper WY
[quote="Muchbroker"]Thank you all -- I wil definetly check the clutch oil level, then try and dislodge the pinion. I really hope that is it.
Muchbroker
Casper WY[/quote]
Shop around on Ebay for the manuals. Some of them are priced quite high and those same ones have been on for over a year. They come up regularly, if you search "caterpillar d2" every few days you'll eventually find one at a decent price, and, yeah watch out for the "shipping Mafia".
The pinion is geared to the pony motor and they always move together. If your pony turns hard, does the flywheel rock back & forth easily for about 1/8" or so? That would indicate a problem with the pinion, allowing the pony to turn slightly and 1/8" or so is about how much backlash is in the gears that transmit power to the pinion. If there is no backlash to be felt it's most likely the pony motor itself. Another possibility is that the pony just overheated. The J series D2's have a small coolant passage between the Diesel Head and Pony Manifold. The lower coolant passage is out of the diesel water jacket (near the pony oil drain tube) through the bell housing and up into the bottom of the pony block. If crud builds up and blocks these passages the pony could overheat and seize, or score a cylinder or bearing.
Rich Salvaggio
D2 5U9917
