Elecrtolysis???
Elecrtolysis???
lil cat mec
Send a private message to lil cat mec
has anyone eer used Elecrtolysis to clean their gas tanks? or any parts? how did it work for you?
im wanting to clean my 22's tank via this method... may start it tonight i just want someones view on it!!!
1935 CAT 22 2f4455W
CAT 951
Thu, Feb 16, 2012 1:01 AM
SpragueM
I have used it with great results on rusted items. Works by "line of sight" from what I am told. Meaning that the area to be treated must be between the + and - electrodes. I have never tried to do the inside of an item, ie: gas tank ,for this reason.
It puts off a lot of hydrogen gas so do it in a ventilated area. My setup is a 55 gal plastic drum and a DC welder. Heavily rusted parts are in for a day, then cleaned as much as possible and returned to the tank to finish. Parts are washed afterward and primed. Takes them down to bare metal and will remove paint.
Matt
Thu, Feb 16, 2012 5:36 AM
lil cat mec
Reply to SpragueM:
Matt
i have just got done setting up the tank... its outside of my shop... i know it will work a little slower from what i understand... when i hooked it up to the batter charger 12amps it started to bubble so i guess ill just sit and wait!
1935 CAT 22 2f4455W
CAT 951
Thu, Feb 16, 2012 6:45 AM
lil cat mec
Reply to lil cat mec:
well after the first 24hrs i dumped it and got a lot of rust out so i rinsed it around 5 times and started the process again! then the next day i did the sae thing with good results... there was bare metal in quite a few spots and a little flash rust in others but for the most part it was clean! so then i rinsed it about 8 times and then dried it out!
1935 CAT 22 2f4455W
CAT 951
Sat, Feb 18, 2012 11:52 PM
