Generator polarizing
sr4440
Send a private message to sr4440
Getting ready to hook up the generator on my D2.
I was searching through the old archives and in one of them, OM replied to someone with a different method of polarizing than is listed in the operators manual.
My generator is a Delco 1102425.
What is the correct method for polarizing this Generator?
Scott
Tue, Feb 14, 2012 6:12 PM
The Delco 1102425 is an "A" circuit generator.
To polarize an "A Circuit" system, connect the FIELD, ARMATURE, and BATTERY leads to the regulator. Connect the battery. Then, momentarily connect a jumper wire between the ARMATURE terminal and the BATTERY terminal at the regulator.
Wed, Feb 15, 2012 12:38 AM
sr4440
Thank you once again OM.
Scott
Wed, Feb 15, 2012 7:42 PM
