D8 ID. ....8R or RD 8
Showing 1 to 10 of 33 results
Gordon.
Send a private message to Gordon.
Any of you chaps have any ideas what the acctual model is ?
Any UK guys know what i would expect to pay for it ?
Thankyou,Regards Tim
Tue, Jan 24, 2012 3:53 PM
ianoz
What , Did you leave your glasses at home Tim . Serial number plate is always the best bet . Know not a lot about D8s ,but i don't think it is an RD8 .. Hope your keeping well .
Tue, Jan 24, 2012 4:35 PM
Gordon.
Reply to ianoz:
Hi Ian, fine thanks. Hope u's well too.
...Do you not think i would have read the plate if it were legible ...😊
Tue, Jan 24, 2012 5:43 PM
catsilver
Reply to Gordon.:
I don't reckon its an RD8 Gordon, much later than that, probably a 2U series from the late forties early fifties, although not one of the last 2U series,you will find the serial number on the bottom flange of the cylinder block, left hand front, close to the timing case joint.
Tue, Jan 24, 2012 7:39 PM
catsilver
Reply to catsilver:
I've modified my ideas a bit Gordon, it is more likely to be mid forties and possibly a late 1H or early 2U, perhaps some else can tell us when the 'gate change' was discontinued.
Tue, Jan 24, 2012 7:50 PM
Richard~J~W
Send a private message to Richard~J~W
Reply to catsilver:
would make a nice little project, Tim
Tue, Jan 24, 2012 7:57 PM
Diggerdozer
Send a private message to Diggerdozer
Reply to catsilver:
I think because of the front idler being solid it is a late 2U as early 2U were spoked
single bonnet? not hinged down the middle would also say it is a 2U
Also the cast piece that bolts onto the front idler and onto the outer rail is 2U
Then D8 13A had a solid front idler also and that started 1953
Another point the hydraulic blade cylinder support group suggest it is post 2U 15001 up as per a parts manual I have
Does it have a single piece bonnet or Hood
Tue, Jan 24, 2012 8:19 PM
Old 3T lover
Reply to Diggerdozer:
I see it has the old "slide shift" so it could be a very early 2U all the way back to a 1H with a lot of upgrades. I have no books any more but the first 12 to 15 hundred 2U's had the slide shift.
The large oil filters, hyd. hard nose, CAT CCU all, in some way, say later model than a 1H or 8R.
Tue, Jan 24, 2012 9:07 PM
Reply to Old 3T lover:
Only things I can spot for sure puts it between 1H1350 (tall injector pumps) and 2U5306 (end of slide bar 194😎. Everything else mentioned could fit this range. Something strange about that oil filter base, could be later engine in early chassis.
The 8R parts manual does show the hydraulic hardnose arrangement but even that could be a conversion.
Tue, Jan 24, 2012 11:42 PM
Kelly
I’m with Old 3T lover. It’s a “slide bar” and could go all the way back to the 1H. But I think it’s is a later D8, the steering clutch handles are of a later tractor. The hood and radiator/dozer shroud are of a later model, It seems they have cut a piece out of the dozer/radiator shroud…..maybe to make it fit up, making one to think it was not meant of that tractor. Interesting anyway.
Kelly
Wed, Jan 25, 2012 12:00 AM
u-joint
Send a private message to u-joint
Reply to Kelly:
Kelly
it looks to be an 8R! could be a 5000 2U like old magnet says. i have never seen a 1H with the short injection pump? i do not have a 1H book. my 8R has the solid rollers and the heavy fenders like that machine.
Wed, Jan 25, 2012 8:34 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
