Battery specifications
Cat951
Send a private message to Cat951
Hi,
you know the battery data Caterpillar 9g4250 h?
Mon, Jan 2, 2012 10:53 PM
The 9G4250 (8C-3629 current number) is a 6v, 780 CCA, 900amp/hr battery. BCI Group #2
Tue, Jan 3, 2012 12:11 AM
Cat951
900amp/hr??
Tue, Jan 3, 2012 6:05 AM
Reply to Cat951:
900amp/hr??
Sorry, one to many zeros....that's 90 amp/hr capacity.
Tue, Jan 3, 2012 7:16 AM
Cat951
Hi Old Magnet,
I found this page, depending on the connections in the first photo, the battery 9g4250 should not be a 120 amp / hr?
http://waterdecontamination.tpub.com/TM-55-1930-209-14P-9-3/css/TM-55-1930-209-14P-9-3_722.htm
My 951 was equipped with 4 of these batteries and I understand that mount aftermarket batteries now.
Hello
Tue, Jan 3, 2012 5:14 PM
Reply to Cat951:
Hi Old Magnet,
Hello
Seems they are always messing with battery specs.
In 1989 the 4G4250 was rated at 115 amp/hr and considered a Heavy Duty/Extreme service unit. (correct for the 951)
You can check current specs for yourself here.
http://www.cat.com/cda/files/2584317/7/PEGP7801-06%20Cat%20Battery%20Specs.pdf
Tue, Jan 3, 2012 10:57 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
