Pony engine exhaust manifold repair
Showing 1 to 10 of 35 results
Delta KJ
The exhaust manifold on my D2 pony engine is cracked. Can it be repaired or do I need to look for an undamaged used one? I welcome any pointers!
Mon, Dec 12, 2011 9:03 AM
Steve A
If the metal is good weld it up, If not I sell replacement pipes that will have to be welded in, usually they rot out on the bend a little higher in in your pic
Mon, Dec 12, 2011 9:09 AM
Mike Meyer
Reply to Steve A:
I had an exhaust shop make me a new exhaust pipe for my pilot motor last year after the old one rotted, they used the old mounting flanges, only cost $60 from memory.
regards
Mike
Tue, Dec 13, 2011 7:13 AM
Delta KJ
Reply to Mike Meyer:
regards
Mike
$60 seems really reasonable for such a repair. If the repair was in the U.S. will you post the name of the company that repaired the manifold?
Tue, Dec 13, 2011 8:05 AM
Mike Meyer
Reply to Delta KJ:
Hi Delta, It was here in Oz, but if you unbolt that pipe I'm sure you will find a exhaust repair joint in your area will do the same deal.
regards
Mike
Tue, Dec 13, 2011 11:12 AM
Julian
Send a private message to Julian
regards
Mike
Hi Delta, my D4 one was like that, That crack will weld easily enough, it's probably worth welding if the rest of the manifold is in better shape. I did mine with my MIG welder after first cleaning the rust off the area. I guess gas weld or TIG would be better but I don't have those in my workshop!
Regards Julian.
PS, it's probably worth adding that this is not the easiest job on the cards for a MIG welder, someone with a few hours experience would be advantageous.
D47J5052
Tue, Dec 13, 2011 3:44 PM
64farmboy
Reply to Julian:
Regards Julian.
[quote="Julian"]Hi Delta, my D4 one was like that, That crack will weld easily enough, it's probably worth welding if the rest of the manifold is in better shape. I did mine with my MIG welder after first cleaning the rust off the area. I guess gas weld or TIG would be better but I don't have those in my workshop!
Regards Julian.
PS, it's probably worth adding that this is not the easiest job on the cards for a MIG welder, someone with a few hours experience would be advantageous.[/quote]
Yep, weld it slow and let it cool down before you strike again, just spots not a continuos weld.
Regards Dennie
Tue, Dec 13, 2011 6:25 PM
Thank you received: 19
Reply to 64farmboy:
Regards Julian.
Regards Dennie
I'd recommend building a jig to hold the manifold while welding or fabricating or it will never match the manifold flanges again.
Tue, Dec 13, 2011 10:26 PM
Delta KJ
Reply to 64farmboy:
Regards Julian.
Regards Dennie
I'm using my MIG welder and the smallest wire that I have; .035" and I'm burning through pipe. Very frustrating! Does anyone have a source for a replacement pipe that I can weld to the flanges?
Tue, Dec 13, 2011 10:28 PM
Reply to Delta KJ:
I once looked into ss tubing from McMaster. They had a long radius el that looked usefull but I did not follow through.
Tue, Dec 13, 2011 10:34 PM
64farmboy
good point
Wed, Dec 14, 2011 12:08 AM
Price Tractor Pull
Price Tractor Pull
