D4 track adjustment spanner part number
callan
Send a private message to callan
hi guys,
anyone got a wrench size or part number for the track adjusting spanner for a D4 6u ?
also, i have a funny feeling that the bolt though the recoil spring is snapped.
i cant see through the spring at all and i have just aquired this dozer.
when i compare the length of springs on either side there is definately a difference,
with the side with the tight track definately being longer.
how bad is this ?
if i use it like this am i setting up for certain deatyh of the track ?
Tue, Nov 29, 2011 6:05 AM
the spring lengths should be the same as there is a back stop and a front stop---the spring bolt is only to hold it compressed to install it. One spring may be broken, has reduced resistance and is compressed somewhat.
I would check that out before using it that way.
Tue, Nov 29, 2011 6:26 AM
josh
Thank you received: 13
Reply to dpendzic:
CATERPILLAR 2 3/4" WRENCH #9F3869
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170735189418&ssPageName=ADME:B😖S:US:1123
Tue, Nov 29, 2011 8:28 AM
