Delco starter interchange
Showing 1 to 6 of 6 results
Anyone have any information about Delco starters to say what family or model a 113039 Delco Remy starter is? On the Delco website it says it's obsolete, no other information. I have one we need to find a replacement for. Not expecting a direct replacement, just something that will fit, modern would be nice!
Tue, Nov 15, 2011 2:46 AM
Thank you received: 39
Do you know the application? and is that all the numbers? Usually Delco uses a 7-digit number.
I have starter parts listing back to 1934 but it does not show that number.
Tue, Nov 15, 2011 4:59 AM
Mike Walsh
That starter comes up as a 1113039 on the Remy site and shows obsolete. No other info available.
Tue, Nov 15, 2011 8:46 AM
Reply to Mike Walsh:
1113039 is a 6V starter used on IHC power unit #RD450 (1957-5😎 only. No replacement listed but appears to be one of the early 30MT units of which there are lots to choose from including 12 & 24V.
If it's just parts you need I can give you the build list. Seems it is the same build as others but there is something different about the solenoid, something to do with a lever??
Tue, Nov 15, 2011 10:55 AM
It's on an IH power unit. U450 6 cylinder propane/natural gas. Beginning to pull lots of amps when cranking. Has just been in the shop, so I don't think there's much that can be done for it and they generator/starter guy seems not to be able to get anything for it anyway. A year ago he ordered a solenoid and it wouldn't fit.
There was some talk about using a 30MT or something like that on the Yesterday's tractors discussion board when I searched there today. Sure would be nice if that number would cross over to something new.
It has 113039 1787 on the tag. It's one with the exposed drive shift linkage/open plunger on the solenoid. I had seen that search result on the Delco website, but didn't catch the extra 1 at the beginning. I wonder how accurate that is because the old one certainly doesn't have that 1 on it. Probably like entering the old CAT parts numbers into the modern system, Have to have the right format.
Searching with 1113039, I find some foreign language websites that seem to indicate it's a 30MT series. I've got some of those around I can stick in it to see.
Tue, Nov 15, 2011 11:01 AM
That 113039 doesn't fit anything in the Delco system....most likely miss stamped. I suspect your going to have to swap nose housings as there are lots of different versions.
Tue, Nov 15, 2011 11:10 AM
jw45
Send a private message to jw45
http://66.46.21.101/RCPOnline/Search_Details.aspx?PART=3600AHDS
Try Here for parts or starter jw45
Wed, Nov 16, 2011 7:36 AM
