D7 17a Direct electric conversion
Showing 1 to 10 of 10 results
farmermattD7
Send a private message to farmermattD7
Seems to be 17a day around here lol
I have searched myself silly for the last couple hours and I think I am more confused than before
Are the parts available for the conversion or do I have to do a hack-em-up to make it work?
I've seen the auto-lec kit online but I have read posts here from a while back that says the parts are not available?
ser. #17A2465
Or I'd be interested in a good running pony if someone had one pretty sure mines trashed...........
Thu, Nov 10, 2011 10:09 AM
Thank you received: 13
Yes, direct start parts are available....requires the special drive end housing, helical drive gear and a 50MT Delco Remy starter motor.
Thu, Nov 10, 2011 12:05 PM
farmermattD7
I guess holes still have to be drilled and tapped for mountin
what is the best source for the parts?
Thu, Nov 10, 2011 12:45 PM
Reply to farmermattD7:
No hole drilling required for the starter. Does involve a 24V electrical system, battery box, switching etc. Are you serious or just contemplating?
Thu, Nov 10, 2011 9:57 PM
farmermattD7
OM I'd say I'm pretty serious this thing is a great starter (I can push it with a bobcat and easily start it) and the pony hasn't run right in years (one cylinder wont fire,bad carb float, rusty fuel tank, and the air breather and associated piping has been gone for years so who knows how much dirt this thing has ate) and i'd like to use it in the near future so yeah i'm probably gonna do it.
Now not saying I might not go ahead and tear down the pony and see what is wrong with it in case I want to do a full restoration on it in the future I could easily convert it back to a pony start and the direct start parts will be in demand if I wanted to sell them
Plus with the front hydraulic unit and no rear unit this thing is front heavy anyway. losing the pony might help matters there as well
Fri, Nov 11, 2011 10:26 AM
This is what it looks like, you can go ahead and find a 50MT starter motor, 24v, CW rotation.....used, rebuilt, new or knock off. If you ship they are heavy and need extra protection for the rear terminal stud. The nose housing and drive they probably will come with can not be used in this conversion.
I'll dig out the source for the adapter nose housing and 12 tooth helical drive in the morning.
The alternator is an adaption from a generator housing, I don't have a source for that particular one. If you are just recharging batteries, no more than 20 amps you can get by without a cooling fan on the alternator, even can use the 10si Delco enclosed (no ventilation holes) housing. If the load is greater a unit with built in fan and ventilation is required.
You can buy the drive and adapter housing here. Either a 12 or 11 tooth (RH only) helix will work, original was twelve tooth. You'll have to call and ask about the D7/D8 adapter housing Stock # 12144 ($56)
as it is not currently listed.
http://www.ebay.com/itm/Caterpillar-Helix-Starter-Drive-40-MT-Conversion-12-T-/350504036439?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item519bab2857
or you can buy the whole works here:
http://www.ebay.com/itm/NEW-50MT-PONY-MOTOR-REPLACEMENT-STARTER-24VOLT-24V-/110606725527?pt=Other_Vehicle_Parts&vxp=mtr&hash=item19c0acb197
Fri, Nov 11, 2011 1:47 PM
farmermattD7
Ok I will probably go with the complete unit but it is listed as an 11 tooth and it says LH drive? that contradicts what you said to order
I figured I could get a battery box off a D7E and Mount on the LH rail along the seat........ switches and the like are no problem Just want to make sure I order the right thing the first time
Old Magnet, I am not doubting you at all I just wanted to clarify........ And I really appreciate your help on this as well as what i have read on other threads that have tought me much
Sat, Nov 12, 2011 8:09 AM
Yes, I saw that, the 11 tooth will work but original pinion was 12 tooth and either is available. As far as their "left angle" or words to that affect, it is apparent they don't know the convention for describing the drive. Correct terminology is right hand helix as viewed from the drive end (motor). The picture I included is correct. I'd have a chat with those starter folks and ask for a picture to get it right. They do make a LH helix pinion also but that's not correct for the 17A application.
Sat, Nov 12, 2011 8:36 AM
Rennix
Send a private message to Rennix
Okay OM,
Will this starter bolt directly to the tranny housing, or will I have to make an adapter plate?
What is the best way to by-pass the water jacket piping that goes into the pony?
Looks like I am gonna be in this around $1000. About what does it cost to just rebuild a pony?
Thanks,
Todd
1953 D4 6U8588 Cat hyd. blade, Hyster D4 winch
1959 955 Traxcavator 12A6595
1959 Rogers/Phelan 25 ton lowboy
1960 D7 17A14922
Thu, Nov 24, 2011 10:04 PM
Reply to Rennix:
Okay OM,
Thanks,
Todd
The setup shown in the pictures bolt directly in place of the pony, no adapter required. Pony costs depend on how much needs to be done but $1,200 - $1,500 is probably a good range for a complete overhaul with you doing all but the machine work.
Just make up some block off flanges for the water connections.
Thu, Nov 24, 2011 10:27 PM
Rennix
Okay, now I've got a really dumb question. Will any Delco 50mt style starter work? There are lots listed on ebay. One even saying it is a direct replacement for the pony on a D7. Does it just need to be a 11 or 12 tooth right hand pitch?
1960 D7 17A14922
Sat, Nov 26, 2011 2:49 AM
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
