D7-17A track master pin removal.
anyoldiron
Send a private message to anyoldiron
l need to replace a seal in one of my grease filled track adjusters and have met some resistance with the master pin.
So far;
l have slackened the track,
Found the master pin ( its the only pin with a dimple in the centre).
placed the master pin at front of dozer
l have a horizontal bottle jack between the C frame and master pin.
l have a 6x6" post wedged from the link/front idler to the opposite frame.
l have used a come along to take the tension of the master pin from track pad below to above (tried several tensions)
lve been soaking the pin with extract of Panther for a while.
lve applied pressure and hit the cframe and center/sides of the pad and the pin has moved about 1/16".
lm on my own so there is a limit to what techniques i can use. lm now at the point where im going to have to apply some serious pressure, i want to make sure im not going to damage anything with the way ive got stuff braced? ls there a better/alternative way for the proverbial one man band?? Does it help to remove a pad or two and put some heat to the link?
Cheers
Thu, Nov 10, 2011 9:50 AM
Leave the track pads on and run the front up against about a 12 in. block hooked under the grouser. Would really help to have some type of pin holder to support the drive pin, usually bolts to a hole in the grouser. Then it's BFH time....don't hurt yourself.....a little heat will help but don't apply to much to where you loose the temper (steel that is LOL). I'm getting to old to do those anymore, last one was for a D6 and I got a hell of a workout. From now on it's hydraulic pusher for me.
Thu, Nov 10, 2011 12:00 PM
AJ.
Send a private message to AJ.
Follow Old Magnets instructions to set the track up for pin removal, you need to make up a pin driver, a piece of bar a bit smaller than the pin with a handle welded to it for a helper to hold or make one like Old Magnet suggested that bolts to the pad,when the driver is made first try to knock the pin out cold and if it does not move after half a dozen blows of at least a 14lb hammer or so heat the link boss rather than the pin,do both sides,the pitcure below will give you an idea of the the drivers,no hammer required with the hydraulic one,you and the helper use eye protection.
AJ
Fri, Nov 11, 2011 5:23 AM
anyoldiron
Reply to AJ.:
AJ
Thanks Gents,
Ended up getting a drift from a neighbour, set it up on top of the C frame on top of a piece of 2x6, got myself a step up level with the C frame swung the 16lb Tool-fine adjustment like a golf club and it came out fairly easy.
l had a feeling the press method was probably causing binding.
Did a quick 320km round trip to the nearest town of consequence and got the seal, $10. Will get that sucker buttoned back up tomorrow, just in time for the freeze and some clearing work with the old beast.
Cheers.
Fri, Nov 11, 2011 8:37 AM
keith
Send a private message to keith
Reply to anyoldiron:
Thanks Gents,
Cheers.
HELLO dont know why you guys fight with track pins old cat man here check the price on the pins you put lots of time in latets pin price for me was 22 dollars from cat not worth putting 5 men hours geting them out cut them off on old machines there worn out anyway
Sat, Nov 12, 2011 1:24 AM
