Well I have tried running the machine.
I am having problems getting it to run smoothly.
Not sure which way to adj. the fuel and air mix, now My arm is about to give out from cranking every few min.
I have attached some pics of the carb.
Is that a 2-Ton fuel filter that I see on that Stromburg? Sorry I can not help with the adjustments.
Ken
Eric ::: Is the " M " carb. for a single cylinder engine ; The " M-2 " for two cylinders ; and the " M-4 " for four cylinders ??????
Erik :::: Hurry, and get that engine running....The electric starter is getting weak !!!!!!!
