Caterpillar 951
Caterpillar 951
Showing 1 to 10 of 27 results
L200PEF
Send a private message to L200PEF
I have just puchased a 951 and the decals on the side are different on each side one is 951B the other side is 951C does anyone know how to find out if it is a plain 951 or a 951C as I have been told? Also how do I tell from numbers what year it is? Also where are the numbers found? Also what is the best oil to put in the tranmission? as it has two dip sticks. 1. dip stick is in the floor in the cab. 1 is under the seat. Does it have to have a diverter valve for a ripper off of the 4 in 1 bucket lever.
Loads of questions but any help would be appreciated. Thank you
Mon, Oct 10, 2011 2:44 AM
hdroadkingc
Send a private message to hdroadkingc
The dip stick under the floor plates are for the Trans. The one under the seat is for the steering clutch housing. Others can help out with type of fluid better than me.
Mon, Oct 10, 2011 7:50 AM
Reply to hdroadkingc:
The 951B became the "C" model at 86J2598 (US built) when the 3304
(78P) engine was introduced in 1973.
I'm somewhat amazed that you'd buy a machine with s/n unknown.
Need to get yourself some manuals and study up.
Mon, Oct 10, 2011 11:44 AM
AJ.
Send a private message to AJ.
One serial number should be located on the left steering clutch housing,looking at the machine from the back,the other under the dash on the firewall just above the right steering /brake pedal,see the picture.
Good luck with your investment.
AJ
Mon, Oct 10, 2011 3:58 PM
Aphonopelma
Send a private message to Aphonopelma
Reply to AJ.:
AJ
I use 10-40W oil everywhere on my machine, engine and hydraulics. The ripper controler would be next to the rear of the RH arm rest, it's not part of the 3 levers for the 4in1 control. I'll try to remember to take a picture of it tonight to post on here.
Scott
1975 951C
Tue, Oct 11, 2011 12:38 AM
Aphonopelma
Reply to Aphonopelma:
I see my last post cracked the 100 Senior Member mark, I certainly don't feel senior :bounce😞I'm only in my 40's) and I definitely consider myself in the junior knowledge category regarding Cats.
Ok, back on topic.
Scott
1975 951C
Tue, Oct 11, 2011 12:48 AM
AJ.
Ok, back on topic.
Cat changed the oil specs for all the powershift machines, the old oil spec of series 3 30W no longer applies,it has changed to TDTO 30W, (Transmission Drive Train Oil 30 weight) the page from original manual below states that all the oils except the hydraulics were SAE series 3 30W,the new spec oil is to increase clutch life.
AJ
Tue, Oct 11, 2011 2:48 AM
L200PEF
Reply to AJ.:
AJ
Thank you everyone for your help it is much appreciated
Tue, Oct 11, 2011 2:57 AM
tctractors
Ok, back on topic.
Lucky for me, I can now class myself tricked up on things 951, if its a C the return to dig control is positioned at the end of the bucket tilt cylinder, thats the bit with the 4 bolts holding the cap in, it also has the 6. 91" track pitch, the plates look very wide, it also should be fitted with SALT chains, plus the loader turret should be heavily plated, with big chunks of Iron welded around the pin locations, the transmission oil cooler is in the radiator area rather than cooled just by water as the B series oil cooler that is bolted to the n/s of the engine, the water pump on the B is bolted on the top side of the gear set, on the C, its bolted into the front of the gear set, the B's have the scroll type injector pump, the C's have the sleeve style pump fitted, the scroll one is in my mind a better thing to have???, the weight of a B is a good bit lighter than the C, they both run the same nasty width pads that could just do with a bit more Iron to keep things afloat when it gets damp, the B is as good as a C in loads of ways, its lighter and is better on fuel, with a bit less HP to damage things, hope this is of some use, the B engine is the 330C, the C engine is 3304, lots of the bits are the same.
catsilver
Reply to tctractors:
Always a straight 30w transmission oil in any powershift transmission, do NOT use multigrade, the needle rollers bearings break the polymers down to the lower viscosity and causes excessive bearing wear. I've seen it, and the oil rep who reomended the 10w/40 oil would not help in the early hour failure!
Wed, Oct 12, 2011 3:38 AM
Aphonopelma
Reply to catsilver:
Thanks for the FYI on the 30WT oil.
Here is the ripper control on my 1975 951C, I've always seen the control in the same place on the C models.[attachment=11094]DSC02556.jpg[/attachment]
Scott
1975 951C
Mon, Oct 24, 2011 10:56 AM
Newby Hall Tractor Fest
