No 25 CCU Query - Handle & Rod Arrangement and D6 9U update
17 years 6 months ago #6103 by David Wills Cat 60
I'm uncertain on the lever handle, collar & rod arrangement on my 32E series CCU, as these items were missing when I brought the CCU.
Unfortunately the exact serial number for the unit can't be distingushed, but looking at the parts book it must be above 32E373 as it has 2 shafts mounted on a block on the RH of the tower assembly, as opposed to the single shaft on the earlier models.
The attached picture shows the CCU.
Can anyone post a picture of a similar CCU?
1948 D6 9U
1963 D6B 44A
1970 951A 63K
1940's Le Tourneau S3 Rooter
www.flickr.com/photos/link_club/
17 years 6 months ago #6104 by David Wills Cat 60
The attached pictures show the current state of play on my 9U restoration. I'm aiming to have it ready, for it's first outing at the Castle Cement working weekend at Ketton on 23 / 24 June 2007. The CCU is the last big item to complete.
1948 D6 9U
1963 D6B 44A
1970 951A 63K
17 years 6 months ago #6105 by David Wills Cat 60
Replied by David Wills Cat 60 on topic My Workshop
My workshop consists of a corner in a field at a friend's farm. If it's raining or snowing I have to make do working under the tarpaulin.
1948 D6 9U
1963 D6B 44A
1970 951A 63K
17 years 6 months ago #6110 by Old Magnet
Your D6 is looking good. That one was a rough recovery.
See you recovered the loss of at least the rear half of the belly pan. Sorry I can't help you with pictures of the 32E CCU. They did have em for the 9U and apparently they evolved from the #25 to the #125 and #126. Just don't see them around much, most are the older 9D501-up units.
17 years 6 months ago #6120 by edb
Replied by edb on topic 25 ccu pix
Hi David,
hope this pic from the OMI will help, do not have parts book.
17 years 6 months ago #6121 by ccjersey
Sharp tractor!. I especially like the exposed radiator and braces vs the usual hardnose.
The CCU looks like it uses the same levers on each position since it already has a taller base under the one for the left drum. I haven't seen one with two levers on it in a while. Had a lever here a while back that was especially tall, must have been for a BIG tractor, not the 9U:D
How did you prep and paint it? It looks really good. Be a shame to get it dusty:p
A neighbor of mine has a complete sandblasting and painting setup on a truck and he gets all kinds of old paint from clearing out closed manufacturing plants and buildings etc. This combination of painting equipment, surplus paint and man results in some strange looking equipment more often than not. :D
17 years 6 months ago #6123 by David Wills Cat 60
OM - luckily I was able to locate replacement crankcase guards, without too much trouble from Robert Wilson (Chapter 2 Chairman). I deliberately now avoid leaving any loose items down on the farm, to save anything else from getting stolen.
Eddie B - thanks for the picture from the OMI, but it looks like it shows the earlier version with only a single shaft mounted on the outside of the tower? I do have a Parts Book, but for some reason it's not very clear on the actual arrangement.
ccjersey - thanks for the comments about my paintwork. Owing to equipment limitations and my open air workshop, I've just been brush applying the paint both insitu on the farm and on smaller items in my garage at home. I've been following a 7 coat application: 1 primer, 3 cat buff primer\undercoat and 3 cat old yellow topcoats. Initially I was using a 4 1/2" grinder with a steel cup brush and or flap disc's to remove the rust \ old paint, but more recently to save time I've sent the items off to a local shot blasting company.
1948 D6 9U
1963 D6B 44A
1970 951A 63K
17 years 6 months ago #6124 by sprocket
Replied by sprocket on topic Black smoke at ketton
Hi Dave your tractor looks really good ,a credit to you and john especially working from that old indian workshop!Hope to see plenty of black smoke at our ketton do.The setting for our AGM was very good although the lack of members was dissapointing.look forward to seeing your tractor and others at ketton.cheers.sprocket
17 years 6 months ago #6125 by MARTYN WILLIAMS
Hello David
The chapter 2 site is up an running,will add more pictures in the next week.
I have had a few phone calls and emails about it.
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 6 months ago #6132 by Old Magnet
Hi David,
Does your parts book show an outside mounting block like you have........thinking that may be a custom made piece.....doesn't look like typical Cat unit.
