Hello Guys
I'm looking for ideas to put my D2 to some use (it's slobbering, so I want to give it some real work !!). I have 10 acres of light sandy soil (ancient sand dune type soils) and live in an area of small farms that run mainly sheep, horses and some cattle, very little cropping is done, its all grass fed stuff.
I've been looking for a blade but even if I get one at a reasonable cost, there won't be a lot of work, and my D2 doesn't have the large idlers and extended track frame to do good dozing work (and I'm very inexperienced at this so would be on a steep learning curve anyway).
The D2 spent most of its life dragging a mole plough, but as far as I can tell, mole plowing in our sandy soil isn't that useful.
So . . . I was thinking about other jobs I could do using trailed implements, and was thinking about some of the modern low-tillage type trailing implements such as subsoilers and chisel ploughs. I have an arc welder, some big box section and a front mounted hydraulic pack, I need is some advice and ideas. Here is one idea, the principle looks interesting (at a smaller scale obviously). Any other ideas ??
Thanks - Foster
