D4 5T - Starting Engine Clutch Oil Capacity Question
Showing 1 to 10 of 12 results
TheFourthHorseman
Send a private message to TheFourthHorseman
Does anyone know how much oil it takes to fill the Starting Engine Clutch compartment?
My book doesn't really give me capacities 😞 It just says to fill until is spills out the level plug opening...right now, I can't get the level plug out.
Does anyone have an idea on how to get that thing out??? Someone in the past rounded one of the edges on the plug a bit & the wrench just keeps slipping off of it. I was thinking heat it with a torch, let it cool & then try to turn it...anyone have a better idea???
At some point, I might just have to breakdown & do the direct electric start method...these pony motors are difficult beast from time to time.
Thanks so much,
Casey
Sat, May 7, 2011 1:11 AM
Mike Meyer
I reckon about half a pint, or 300 mils of ATF is what you need, try and flush the old oil and crud out first using the front drain plug and some gas or diesel.
If you can't get a pair of locking pliers to grab that rounded off plug I'd suggest you weld a good nut onto it though I'm always worried about welding around items with bearings, you need to be very careful about where you place your earth lead so as not to have current running through bearing races.
Another option is to use a small grinder or file to create square faces on that plug again.
Good luck
Mike
Sat, May 7, 2011 2:15 AM
TheFourthHorseman
Reply to Mike Meyer:
Good luck
Mike
Mike,
Thanks for your reply. It is in such a weird area to get to. I am pretty sure it rules out the welding chances 😞 I'm on my way to get some better locking pokers...if that doesn't work, I'll try the filing approach.
I wonder if JB Weld would hold? I will definitely replace the plug with a better quality one!!!
Thanks again Mike!!!
Casey
Sat, May 7, 2011 2:48 AM
Mike Meyer
Reply to TheFourthHorseman:
Mike,
Casey
[quote="TheFourthHorseman"]Mike,
Casey[/quote]
You will win Casey, just remove that lower engine side cover so you can swing the 10 pound hammer better and give it a few good belts to smarten it's attitudeπŸ˜–mokin:πŸ˜†
JB Weld will take 24 hours to properly harden and I think you might not get enough adhesion, I'd try a small pipe wrench first, those guys will grab most odd shaped heads.
I used a small auto parts sprayer running off my air compressor with kerosene to shoot at all directions into that clutch compartment to better flush out the old crud from my RD4, it seemed to work OK.
regards
Mike
Sat, May 7, 2011 5:01 AM
chriscokid
Casey[/quote]
regards
Mike
I got to ask...
Casey, what are locking pokers?
Sat, May 7, 2011 5:20 AM
Reply to chriscokid:
I got to ask...
no matter what i tried--heated 3 times, beat on it with a lump hammer, vice grips and a small pipe wrench, i could not get the drain plug 2b7409 out so i over flushed and let the extra flow out the level plug---but my pinion still grinds when i try to engage it. :Cry:
Sat, May 7, 2011 6:29 AM
Mike Meyer
Reply to dpendzic:
I've got my RD4 snap over adjusted just right but I'm the same, I almost stall the pilot motor trying to get it in gear, and the grinding is heart breaking, but I just slam it in and once it's in gear it is fine, it will slip OK. One of these days I'll need to remove that puppy.
regards
Mike
Sat, May 7, 2011 10:53 AM
I think I would try a socket on it. Not one of the 8pt ones for square shanks etc, but a regular 1/2 drive socket turned backwards and then put a bolt head in it etc to turn it. Like Mike says, you may need to square it up a bit with a grinder so the socket fits right.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timeπŸ˜„
Sat, May 7, 2011 11:34 AM
TheFourthHorseman
ccjersey,
I hadn't thought about that idea before!!! I will give it a try the next time that I'm out at the Cat.
My top drain plug I think I used 5/8 wrench to loosen and I think the bottom I had to use a 13 mm wrench. I'm assuming that the guys I bought it from were really good at rounding stuff off and filing it back square 😞
Thu, May 12, 2011 5:01 AM
dick
Send a private message to dick
ccjersey,
Casey, according to Cat Form 10259-1 the clutch of 4G thru 5T D4 holds one pint, the U models hold 5/8 of a quart.
Thu, May 12, 2011 9:28 PM
TheFourthHorseman
Reply to dick:
Dick,
What book is Cat Form 10259-1??? I can't seem to find it 😞
THANKS!!!
Tue, Jan 10, 2012 6:16 AM
