Very OLD Caterpiller Grease PUMP Info?
Showing 1 to 10 of 13 results
IronHorse
Send a private message to IronHorse
I have this Old Caterpillar Semi-Fluid Grease Pump. It has a Riveted Tank that is 16 tall by 8 wide. The lower part of the stand, the Handel, Hose and fittings look like they have been changed or repaired. The Tank, Brass Tag and Pump appear to be good original. My Question? What Era or Year is this? Is there anywhere I can get some Information? … THANKS, Nick
Fri, May 6, 2011 4:02 AM
8C 361
I think those came with the early Ten and Fifteen.
Fri, May 6, 2011 4:30 AM
Tom Madden_archive
Reply to 8C 361:
Best actually used those pumps with the 60 and 30 prior to the formation of Caterpillar in early 1925. The pumps were carried over with the Caterpillar line up after the formation of Caterpillar.
Fri, May 6, 2011 5:04 AM
Jon
Send a private message to Jon
Reply to 8C 361:
The early ones have "BEST" on the brass tag. The handle on top is the same as the door handle on the wooden cabs. I see the crank handle has been lengthened, like the one I have. Jon
Fri, May 6, 2011 5:08 AM
Jon
Reply to Jon:
Just another picture
Sun, May 8, 2011 7:19 AM
Willie
Reply to Jon:
If you look close some of the parts are Cat tractor parts the packing nut has L no. and is a 20 waterpump packing nut the pump gears are 30 oilpump gears cranks is made like the tractor crank Ect.
Sun, May 8, 2011 7:25 AM
D6 Pete
Reply to Willie:
Hey Willy, do Jackie like the fumes from the little 10 when she works hard!?.. looks like the ex pipe could do with a half turn!!. Hope you are both keeping well.. Regards your ol' aussie mate peter.
Sun, May 8, 2011 3:34 PM
John from Fresno
Reply to D6 Pete:
Were these pumps used for grease for rollers or gear oil for finals and transmissions. I bought one of these pumps and looked in my CAT 15 Operators manual and see them in pictures filling finals and greasing rollers. Surely they didn't use gear oil in the rollers....
John
Tue, May 10, 2011 11:36 AM
Cat10
Send a private message to Cat10
Reply to John from Fresno:
John
I have a grease pump for my Ten. It is for the rollers, the pivot shaft bearing and the front idler. I am actually removing the 50 year old semi fluid...gunk that is inside. Mine was almost full. It is not gear oil. It should be Track Lube nowadays
Wed, May 11, 2011 10:57 AM
Jon
Reply to Cat10:
After some discussion with several club members it seems there are three different versions
of these pumps including a Holt version.
Sun, May 5, 2013 1:20 AM
B4D2
Reply to Jon:
Jon, is yours for sale?
Sun, May 5, 2013 1:48 AM
