Motor Grader manual question
17 years 6 months ago #5670 by techieguy
I have a road grader that I need a manual for. One of the members here has a manual that maybe suitable. Being a novice about cats, could someone tell me if the below manual will work for the Cat road grader that I have.
Cat 12
6 cyl with pony motor.
serial number:It appears that the grader serial number is 70D3257 according to a small plate on the front of the grader.
___________________________________
Here is what I have, you will need to check and see if this will work for your serial number. Parts manual for (k2854 and up. Operators manual for 8T1 and up. Let me know if you are still interested in either of these manuals. Have a greta day!
Chad
Looking forward to your responses!
Charles
17 years 6 months ago #5673 by ccjersey
they won't be completely useless, but they aren't the right ones for that grader.
They come up on ebay quite often or get a reprint from CAT. Look at the CAT parts source listing at the top of the board and there is a number for CAT manuals. I believe there is also a website. Probably cheaper to order direct from CAT instead of going through your dealer.
17 years 6 months ago #5674 by Old Magnet
The 8T preceded the 70D & 71D models. All the info in the 8T manual would pretty much be the same except there is nothing about the oil clutch which some/all the 70D's had. May even be a case of the 8T Servicemens Reference Book form #30124-3 is all that is available as I did a search on the Cat Legendary Literature site www.cat.com/cda/layout?m=90800&x=7 and could not find a service manual for the 70D. They do have parts manuals and owners manuals for the 70D.
17 years 6 months ago #5686 by techieguy
Thanks for the information!
I don't thinks I need to worry about the clutch, I need to get the poney motor going first (no spark out of the mag) and then move onto the diesel. Suposedly this grader had problems with the carb on the poney motor when parked 5 years ago, but the fuel line and bowl where pretty much plugged and that could have been problem.
Since I not familar will road graders or large Cats, is there a way to tell if this grader has a oil clutch?
Again, thank for the replies!
Charles
17 years 6 months ago #5688 by Old Magnet
Look for a dip stick and fill plug on the clutch housing, also an external cast housing connection from the clutch housing going to the engine on the LH side. The oil clutch uses a added section to the engine oil pump as scavenge pump for oil circulation to the clutch.
17 years 6 months ago #5695 by D4Doug
Replied by D4Doug on topic 70 D And 71 D
Techieguy,
I have owned a 70D and currently have a 71D, which is the direct electric start version. I have never seen an oil clutch on any of these units. They have a drive shaft that drives the clutch and an inner shaft that drives the mechanical controls. I have manuals for the 8T and 70D versions and they are not very different. The 8T had the starting engine controls on the side like dozers and the 70D has a linkage system so that the starting engine could be run from the operators seat. I also have the serviceman's reference books so I might be able to find what you need.
17 years 6 months ago #5698 by techieguy
Thanks again... I just got home from work and will check the what OldMagnet has said!
D4Doug,
I do remember a plate being on the LH side of the motor for an electric starter...And it does have the starter controls on the LH side of the operators compartment.
Thanks to all for all the answered question thus far! You guys are great! Hopefully I gain enough knowledge with this I coul pass some along to another novice... I won't ever be as some of you, after reading some of the post here... What a wealth of knowledge!
Techieguy
17 years 6 months ago #5700 by Old Magnet
Hi D4Doug,
Does any of the literature you have cover the oil clutch???
Was just looking at a unit with oil clutch a couple of weeks ago. Would have pictures too, as it was a curious arrangement but the dummy forgot to bring the disk for the camera. Oh well, maybe I'll get a chance to go back for another take.
17 years 6 months ago #5701 by techieguy
I just checked the grader and I didn't see and oil fill or dipstick around the clutch housing. So I assuming I should purchase the manual that cover the 8T. Even if its not exact, it should be close enough for getting the beast started and running.
Thanks again!
17 years 6 months ago #5702 by ccjersey
The in-seat starting system is likely to be a little different than the older 2 lever controls on the side of the engine, but the principal would be the same..
Make sure transmission is in neutral and brake is on
Decompress the main engine, close throttle to shutoff position
Start the pony motor, warm it up and rev it up
brake the pinion/quickly engage the pinion gear with the flywheel ring gear
engage the pinion clutch to turn the main engine
apply compression to warm the main engine and get the oil pressure up for a minute or longer if needed in cold temperatures
open throttle to start, If it doesn't fire up, close throttle again and let it warm up some more being turned with the pony motor.
It should make white smoke whenever the throttle is open if it getting fuel to the cylinders.
Have fun
the 99E (12E) has an oil clutch that uses the engine oil supply and a scavenge pump to supply the clutch. No rear main seal even. There are some sealing rings on the flywheel to seal the oil going from the clutch housing oil passages into the clutch. Still have to get ours back together.
