Grease gun fittings
Grease gun fittings
Showing 1 to 10 of 16 results
Julian
Send a private message to Julian
Today I planned to grease up the track rollers and front wheels (not sure if wheels is the right term?) on my D4.
I fitted my new slide on fitting, that I got off ebay as I have never used this sort before, to my grease gun and discovered that it was too small for the D4's fittings 😞
This is what I purchased: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190430391945&ssPageName=STRK:MEWNX:IT
I'm sure I'm heading in the right direction with fitting type, but obviously need a physically bigger item - any ideas what I should be looking for?
Julian.
D47J5052
Mon, Apr 11, 2011 1:57 AM
trucker1
Send a private message to trucker1
You probably are looking for what I was always told was a "giant" button head fitting. The regular size, which you have is 5/8 and you nmeed 7/8 See the Mcmaster site I have attached
George
http://www.mcmaster.com/#grease-fittings/=bti3d0
Mon, Apr 11, 2011 3:45 AM
JasonPayneCrawlers
Reply to trucker1:
George
Here is one,like the one I use heavy duty.
http://www.grainger.com/Grainger/WESTWARD-Button-Head-Coupler-3APG5
Mon, Apr 11, 2011 6:21 AM
Willie
Reply to JasonPayneCrawlers:
If you had right size that type would work but JD made smaller button heads the Cat so you need the Cat size. Next you need to have a Allimite track grease pump that is high volune low presure a reg. grease gun unless your very careful will blowout the seals which many are already don, then you need to use roller grease, that is like a very very heavy oil and runs about like honey.
The wheel is called the front idler
Mon, Apr 11, 2011 9:18 AM
Julian
Reply to Willie:
Thanks, via google I've found a UK based supplier that advertises giant button (7/8th) size so all being well I'll buy one tomorrow. I'll get the right lubricant too, I know what it is as the automatic chassis lubricator on my tractor unit (semi-rig in US?) uses the stuff - it's like oily gloop.
Now all I need to do is improvise a way of filling the things with oil and not overpressurise and pop the seals. Maybe I could use a syringe type devise?
I changed the final drives and gearbox oils today. Also I removed the ''wading plugs'' from the brake housing compartments and got at least three gallons of mucky oily water out of one - I got soaked😞😞 I removed the square plates at the back and the large inspection plate by the seat. I guess the brakes and clutches will work better when they dry out and are no longer under water!
Just a quick question, while changing the starter pinion housing oil I discovered a zerk fitting beneath the left hand pony motor cylinder. It was a vertical fitting and so impossible to get the gun on. I changed it for a 90 degree fitting and gave it some shots of grease (guessing this was a good thing!) Moving back now behind the bullhead the floor board there has a little bulge in it to accommodate the starter drive with a small 1/2" hole in this bulge. I dug around in there expecting to find another zerk fitting but just found a small set-screw. Should there be a zerk fitting there or not?
Thanks Julian.
D47J5052
Tue, Apr 12, 2011 3:07 AM
Willie
Reply to Julian:
Thanks Julian.
You should really get a Opperaters manual it has big triple page foldout that has all the lube points and how often you should use them and what lubes to use. There are 4 throwout bearings on the tractor and a bunch of main clutch and steering clutch levers & componits along with a buch of undercarriage parts,water pump,ect. and all take diff amounts at diff hours of use. and there are a bunch of compartments on the tractor that have to be kept full of lubes also Get on EBay or add for one in our buy and sell sections here, so you dont find out the hard way that you missed any. Also under the tractor there are 3 drain holes that you need to make sure are kept open so seal leakage wount reach the 3 clutch mechs.
Tue, Apr 12, 2011 3:30 AM
Julian
Reply to Willie:
Thanks Willie, I've been looking on ebay every day now for a while. I have someone close to me who can let me copy/borrow some manuals as an interim solution but I will get my own at some stage.
There's non available now I'm looking, as soon as I have one there's will be another 10 on ebay the next day (all cheaper and better condition) 😞
Julian.
D47J5052
Tue, Apr 12, 2011 4:05 AM
Willie
Reply to Julian:
Julian.
try this place they may have 1 http://stores.ebay.com/JT-MANUAL-SUPPLY Not all his stuff is listed you may want to EMail him and ask if hes got 1
Tue, Apr 12, 2011 11:55 AM
The other drain plug is in the main clutch housing. It can accumulate oil from the engine and transmission as well as water.
Another hidden grease fitting is on the main clutch pilot bearing. Grease fitting is on the rear face at the outer edge of the flywheel. Doesn't take a lot of grease, just a couple shots very infrequently. Too much will get into the clutch and make it "sticky". You'll have to take off the clutch adjustment cover to see that one.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timeπŸ˜„
Tue, Apr 12, 2011 7:50 PM
Julian
Reply to Willie:
Have sent him a message - fingers crossed.
Julian.
D47J5052
Tue, Apr 12, 2011 9:26 PM
Julian
[quote="ccjersey"]The other drain plug is in the main clutch housing. It can accumulate oil from the engine and transmission as well as water.
Another hidden grease fitting is on the main clutch pilot bearing. Grease fitting is on the rear face at the outer edge of the flywheel. Doesn't take a lot of grease, just a couple shots very infrequently. Too much will get into the clutch and make it "sticky". You'll have to take off the clutch adjustment cover to see that one.[/quote]
Found it and greased it! Also lubed all the various pivot points on the clutch linkage too. And watched oil go down the little funnel.
Does the starter pinion gear and the flywheel gear run dry - like on a motor with electric start?
Julian.
D47J5052
Tue, Apr 12, 2011 9:29 PM
