Reproduction Carburetor for ten or fifteen available?
Showing 1 to 10 of 10 results
tailseat15
Send a private message to tailseat15
Does anyone know if such a thing exists? I thought I saw them advertised one time, but perhaps I was dreaming. Thanks Or, howabout any other side-draft carbs that are easy to substitute/adapt to work?
Sat, Mar 26, 2011 10:58 AM
hicrop10
Bill Campball the fellow that does rebuild them was trying to have one made out of brass,but it was very $$$$.So he stopped it.I was told sometime ago that a carb off of a John Derre B would work.It would be nice to have something that worked a little better then the orignal carbs.
Sat, Mar 26, 2011 6:02 PM
tailseat15
Reply to hicrop10:
Thanks HiCrop. I agree about it being nice to have an option. For example, on the early Jeep 4 cylinders, you can buy a replacement Solex carb. It is not exact duplicate of origional, but will bolt up in place of the origional, and has better performance than the origionals. I think this would be a great option, but I know the #'s are much smaller for the tractors than Jeeps (in terms of potential sales).
Sun, Mar 27, 2011 1:15 AM
Arborigine
Send a private message to Arborigine
Reply to tailseat15:
VW Solex carbs are easy to find, cheap, and adapt to a lot of engines. If my pony carb was corroded I might have used one. At work we are a Weber and DelOrto dealer. There are many adaptors for sale, but i have made them using as little as a drill, hole saw, and die grinder. You can calculate the size carb needed here, http://www.gtsparkplugs.com/CarbCFMCalc.html
[img]http://i221.photobucket.com/albums/dd236/arborigine/7d7c.jpg[/img]
Sun, Mar 27, 2011 1:36 AM
tailseat15
Reply to Arborigine:
That's true the solex's are fairly inexpensive, but the VW carbs are downdrafts, and we need a sidedraft for the tens and fifteens. I will look around when I have some time. Perhaps if you have time Ab, see if solex or someone has a sidedraft model available?
Sun, Mar 27, 2011 7:54 AM
Arborigine
[quote="shimizu1"]
Perhaps if you have time Ab, see if solex or someone has a sidedraft model available?[/quote]
Oh, I forgot how it mounts. Non of our suppliers make a single-barrel side draft that I am aware of, but we do have a pile of nasty old SU and Strombergs, if you want to complicate things. Solex did make a side draft for early VW Squarebacks, but they are pretty rare in the USA. I have a few updrafts in the shed, but they are for big straight eights.
Sun, Mar 27, 2011 11:07 AM
Steve A
[quote="shimizu1"]
even a sutiable updraft, making a elbow with flanges wouldent be a big deal,Not something I would do for a nice machine but workable for a log skider
I have considered converting a rough pv15 I have to a throtle body fuel injection set up
for a project, likely salvage the stuff of a small GM car.
Lke I need another project
Sun, Mar 27, 2011 7:04 PM
Reply to Steve A:
I saw a 10 with a downdraft carb on it last year. I have a parts 10 out back with a plumbing elbow and an Zenith updraft on it.
Sun, Mar 27, 2011 8:09 PM
Willie
Reply to drujinin:
I have seen many diff carbs on the and most common side draft used is a Model T Ford carb but have also seen many with side draft motorcycle carbs
Mon, Mar 28, 2011 12:05 AM
tailseat15
Reply to Willie:
Good discussion guys, thanks for the ideas. Oh and Willie, I'll have to look into the Model T carbs, I think I have access to one for measuring.
Mon, Mar 28, 2011 8:32 AM
skippopotamus
Send a private message to skippopotamus
Willie, do you have any pictures of motorcycle carbs or any ideas what carbs they were? Our carb seems ok now that we have a new top for it but its expensive to work with and I'm not that impressed with how well it responds to adjustment. Carbs today are so much better than the Ensigns.
Tue, Mar 29, 2011 6:24 AM
