Cat Grey paint in spray cans?
Showing 1 to 9 of 9 results
tailseat15
Send a private message to tailseat15
I've tried the search feature without much luck. I'm working on some small parts for my big fifteen and want to paint some small parts. Does anybody know if there is any spray paint available that matches the correct grey color for these tractors? I have the "old equipment yellow" for the yellow ones, but what about the grey ones? Thanks
Sun, Mar 20, 2011 11:27 PM
Lance Jones
Don't know about USA but over the Pond here when I get a New colour , I ask my Paint Man to put some of it into Pressure Pack . I know exactly what you mean , those fidley bits that need a coat and you don't want go to the trouble of setting up your gun . I also carry Etch Primer in cans for same reason . Not cheap but saves a lot of time and no Waste . LJ
Mon, Mar 21, 2011 12:04 AM
John from Fresno
Reply to Lance Jones:
shimizu1
Go to Orchard Supply. There is a color called "Tool Gray" that is very close. It is in the Orchard Brand of spray cans. At least it is cheap and easy until you can spray everything with the big gun.
John
Mon, Mar 21, 2011 1:31 AM
D8PETE
Send a private message to D8PETE
Reply to John from Fresno:
shimizu1
John
Shimizu1 - I painted my Cat 60 about 13 years ago and used paint from Cat and the color was called "Dawn Gray". I was able to get it in gallons and spray cans. I would touch up any spots that needed it with the spray cans as time went on. Just the other day I was at our Cat dealer picking up some parts and asked one of the parts guys for a couple cans and they said that the color has been discontinued by Cat. So I now am also in the hunt for a close match. I will have to look into John's suggestion.
Mon, Mar 21, 2011 1:59 AM
tailseat15
Reply to D8PETE:
Thanks a lot guys, I'm off to the hardware store!
Mon, Mar 21, 2011 2:04 AM
Joe R
Send a private message to Joe R
Reply to tailseat15:
For cat gray-Try www,VALU-BILT.com. I orderd paint from them formy farmall regular.(gray). They used the orgnal formula from int. they will get you cat gray and have it in spray cans too.
Mon, Mar 21, 2011 3:31 AM
Joe R
Try www.VALU-BILT. I orderd paint from them for my farmall regular (gray). Thay used the oregnal formula from INT. They will make you the oregnal paint for cat. they also will put it in spray cans, for touch up jobs.
Mon, Mar 21, 2011 3:43 AM
Tim Stangeland
Send a private message to Tim Stangeland
Reply to Joe R:
I e-mailed ValuBuilt and asked about Cat gray and received a reply stating they can't provide "Cat Gray". What do you make of that? Is there a contact person in the paint department?
Fri, Apr 15, 2011 3:13 AM
dtallon
Send a private message to dtallon
Reply to Tim Stangeland:
Just wanted to add in my 2 cents. I probably tried a dozen different brands and shades of gray paint when I was redoing my Riecke Thirty model. The one I finally settled on was Valspar Gloss Medium Grey 65041 that I got at Lowes. Comparing it to the Norscot Twenty, which was matched to the federal standard color ACMOC specifies as Cat Grey, it is a little darker, but if they aren't sitting right next to each other you don't notice the difference.
Dave
Sun, Apr 17, 2011 8:04 AM
Tim Stangeland
Reply to dtallon:
Dave
Thanks for the tip Dave. Will give Lowes a try.
Tue, Apr 19, 2011 10:21 AM
