Electric starter for D7 4T Pony (Donkey) motor
Showing 1 to 10 of 16 results
Fower VF
Send a private message to Fower VF
Having got tired of swinging the pony, or donkey as we call them, I decided to look for an electric start. I didnt want a direct electric start, a) not original enough, b) the secret of long life of these big cats is that slow steady start up procedure that the donkey forces you to do. The donkey motor had been getting more and more troublesome, a number of people around the yard now have nasty scars on the backs of their hands where the handle has kicked back and flung the hand back into the main exhaust pipe. Even when everything goes according to plan, balancing up on top of the track and pulling towards you is somewhat precarious. I have twice had the thing go easier than expected, pulled too hard and fallen over backwards off the track. For the last couple of years it seems that donkey had been getting more and more vicious and cantankerous and nobody wanted to go near it. We have been bump or tow starting the 7 most of the time. Which is all very well but a) you dont always have another big tractor handy and b) I'm not sure that a sudden start like that is good for the main engine.
I knew that Cat had made an electric start attachment for the donkey, with a 6v motor, but just couldnt find one here in England. My guess is that because most of the D7's of that era over here were 4t's, the military version, they probably never had the luxury of electric start. I posted a wanted ad on the ACMOC BB and Josh Latkin kindly provided and shipped it from the USA. All he had was the gear mounting casting and the ring gear, but this was a great start.
[attachment=8377]d7%20pony%20gear.jpg[/attachment]
Now it was just a simple matter of finding a starter to fit. Hmm, not that simple. That intermediate ring gear is a long way into that housing; so I had to find a starter with a long shaft, the right end gear and a housing that could be adapted to fit. Plus I needed to check direction of rotation. At first I worried about the fact that the extra gear would mean a reverse rotation of the starter to a normal engine layout, but then again the fact that this gear enters the flywheel from the oppsite side to most starters (it faces into the engine flywheel, rather than coming at it from alongside the engine) would cancel this out. (more on this later).
So I searched through all the old starters from the scrap heap and other dusty areas of the workshop and sheds that I could find. This was just the final shortlist from over 20 contenders:
[attachment=8378]IMG00436-20110302-1845.jpg[/attachment]
Having found one with the right end gear, seemingly the right rotation, and a small diameter that could be worked down into the housing it was disappointing to find that it was completely burnt out when I tested it. The second runner had the right gear, a long shaft and it worked. But the housing was all wrong. This means I am going to have to make a new nose cone and components in order to fit it. I dont need a bendix spiral on the starter, and dont need any form of solenoid to help throw the starter gear into the ring. The CAT part intermediate gear is on a sliding shaft and is evidently pushed into contact with both the staretr and the ring gear by a hand operated lever. This helps me to gain some of the extra reach on the starter shaft that I need, I can push the starter gear to end of its bendix and fix it out there.
Here is the starter motor gear on the left and the CAT intermediate gear in its housing on the right, a good match:
[attachment=8381]IMG00435-20110302-1842.jpg[/attachment]
Stripped the motor down to reveal the entire shaft and the bendix spiral on it, if I can make a new front end casing for it to enclose that shaft and house a bearing, at 4" diameter, it will slide down into the CAT housing and I can fix that end gear in the right place to mesh with the intermediate gear.
[attachment=8380]IMG00434-20110302-1841.jpg[/attachment]
The start of machining the new end piece that will replace the existing flange on the starter and allow it to slide down into the 4" circular housing of the CAT part; more to come.
[attachment=8379]IMG00430-20110302-1806.jpg[/attachment]
Nick
Cat D7 4T; Cat 951 A
Fowler VF crawler
Aveling Barford DX8 roller
Ransomes TS 69 hexatrac plough (2)
Ransomes mole plough
Wed, Mar 16, 2011 2:13 AM
The D7/8 uses a Delco Remy Starter #1107029.
The drive end housing is a #1881191 and the drive is a #2A-5127.
2A-5127 is Delco's new numbering system.....the old number for the Bendix Drive is a 1868804....fits a whole bunch of stuff.
Wed, Mar 16, 2011 3:29 AM
SpragueM
The factory starter does use a helical drive bendix. I just replaced the one on my D73T. The entire assembly slides on the shaft and is held in place with a set screw.
Matt
Here is a link to the one I purchased, it is listed for a John Deere tractor but they are the same.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250610306628&ssPageName=STRK:MEWNX:IT
Wed, Mar 16, 2011 4:18 AM
Fower VF
Reply to SpragueM:
Matt
Thanks for the links guys. I probably should have just asked in the first place. But I am beginning to enjoy this little project. I am between jobs at the moment and a spell polishing up my machining skills will keep me out of mischief!!
Just worked out something else to do with the rotation of the thing. That donkey engine runs the other way round to a normal engine. It has to because the pinion is turning the flywheel of the main engine. I think I am going to be OK still, a) because I am pinning the starter gear onto the old bendix shaft and b) it looks like my donor starter ran the other way and pulled the gear into the flywheel of whatver it was on originally rather than pushed it onto it.
[attachment=8384]IMG00432-20110302-1806.jpg[/attachment][attachment=8382]IMG00431-20110302-1806.jpg[/attachment]
I managed to finish turning the first part last night. The long cylindrical piece is to slide down into the CAT housing, the existing starter gear and its female bendix sleeve fits up the middle. The small flange on the end butts up to the starter. The original starter end had no bearing as such, just ran in a bush, so I have just machined the inside of the piece to a very fine tolerance to allow the starter gear piece to rotate in there. The other photo shows the end of the piece that will mate up to the starter body itself, I have opened this out to give it a bit more room. Photo of the 2 1/2" drill I used to rough this out on the lathe.
[attachment=8383]IMG00433-20110302-1807.jpg[/attachment]
I had a slight technical problem here as the only blank billett I had, whilst big enough diameter to make the piece that slides down into the CAT housing wasnt big enough to be able to turn down the match up into the starter. I now have to make a short piece to connect the two, this is a help anyway as it allows me to work on the starter mods in sections.
I'll do a bit more tonight.
Nick
Fowler VF crawler
Wed, Mar 16, 2011 3:45 PM
tctractors
Reply to Fower VF:
Nick
Fowler, if you get into a snag, I have a motor or 2 in my heap of things that might be handy one day??, it looks like you are making a Top job of getting things sorted with what you have, its good to see the progress you have made, well done.
tctractors
Thu, Mar 17, 2011 1:04 AM
d4c24a
Reply to tctractors:
tctractors
excellent and informative post ,thanks for taking the time to post 👍
hope all go's to plan ,keep us updated
thanks graham
Thu, Mar 17, 2011 3:47 AM
Fower VF
Reply to d4c24a:
thanks graham
A bit more progress. I have now turned out the extra piece of starter casing that I needed. As explained, the billet I used for the nose cone wasnt big enough diameter to match the starter so I found a bigger lump, an old cast chain sprocket.
[attachment=8391]IMG00429-20110302-1806.jpg[/attachment]
Turned this down to match the outer shell of the starter and have enough room inside for the works. It needed a lip on either end, one to match the starter housing and one to hold the nose cone. Also had to mill out a groove in the one end to take the locating tab on the starter. I put a dowel in the other end to match up with a slot in the nose cone, all helps to stop the housing spinning.
It fits. [attachment=8392]IMG00437-20110304-1032.jpg[/attachment] You can see the two copper lugs sticking out that connect back to the field coils.
Next issue was the fact that the old nose cone on the starter used to house a solenoid and all the switch gear. I have done away with that and so needed to reconnect the field coils. I used a piece of flattened copper pipe to fashion a sort of buzz bar,
[attachment=8393]IMG00438-20110304-1125.jpg[/attachment]
power comes to this through a bolt that sticks out through a hole I drilled in the new housing extension. Insulation of the power input is by running the bolt up through a hard plastic tube.
[attachment=8395]IMG00441-20110307-1923.jpg[/attachment]
And there it is, all neatly fitted together, new and old housing shells, shaft and rotor, final piece of insulation shield, the white semi circle, (a piece of thick plastic bottle!) and ready for the nose cone.
[attachment=8394]IMG00443-20110309-0925.jpg[/attachment]
Next job is to drill and tap holes in the nose cone, this will allow two lengths of threaded bar to pass from back to front of the starter and pull it all together.
Nick
Fowler VF crawler
Thu, Mar 17, 2011 2:55 PM
SpragueM
Reply to Fower VF:
Nick
Nicely done. Quite the bit of ingenuity.
Matt
Thu, Mar 17, 2011 5:55 PM
Fower VF
Reply to SpragueM:
Matt
I decided that the bendix was redundant but now have to lock the starter sprocket in some way. Didnt fancy drilling and pinning it as ti might weaken it. So simple solution is to make a long spacer, over the bendix spiral that prevents the gear coming back down the shaft. It stays out at the end where I want it, I left a bit of space so it can move around a bit out there.
machining the spacer shaft, with a hole up the middle.
[attachment=8396]IMG00442-20110308-1530.jpg[/attachment]
And here is the finished article, most of the hard work is hidden on the end of the starter up inside the CAT housing.
[attachment=8397]IMG00444-20110309-1025.jpg[/attachment]
I spun it up, but had a bit of a disaster as I had forgotten to fit the circlip on the brush end of the motor and the rotor tried to come out of the other end.
[attachment=8398]IMG00445-20110309-1437.jpg[/attachment] A lot of noise, but only a bit of damage. Should be OK. Ran it up again and guess what? Although it runs up sweet as a nut, the motor is going backwards!! I have no idea what that arrow on the side of the motor body is for but it ain't showing the direction of rotation.
From memory, the way to reverse a DC motor is to switch over either the field coils or the armature, but not both, (hence just switching polarity of the overall feed does nothing). I will check this out first, but I think this is still doable. At least the motor and my workmanship is good, (have to look on the bright side).
Nick
Fowler VF crawler
Fri, Mar 18, 2011 3:42 PM
Old 3T lover
Reply to Fower VF:
Nick
I seem to remember an old fellow telling that those starters used on the pony motors were the same as some starters used on Chevrolet cars of the 30's & 40's. Finding one of those would probably be impossiable now though.
Sat, Mar 19, 2011 2:00 AM
Fower VF
Reply to Old 3T lover:
Have checked on how to reverse a DC motor. I need to change either the windings or the armature. Windings will be difficult as I would need to send wires from front to back of motor. Swapping over the armature wiring looks easier, but not simple.
The brush holders are rivetted to the end cap of the motor, 2 of them take feed from the coil windings and two go to earth on the motor chassis. I think what I have to do is to move round the positive feed through 90 degrees so that it contacts a different point on the armature. I cant just move the wires round because the set of brushes that I need to take the positive to are fixed to the casing and so go direct to earth. The two positive sets of brushes have a mica or bakelite sheet under them where they sit on the end cap. Looks like I need to take all the brushes off and then move the insulation round so that the next set are insulated and can take the positive feed, before I take a lead off the coil positive and take it to these brushes instead.
Photo shows the brushes on the motor end cap and the pair with the insulation under them.
[attachment=8403]IMG00446-20110309-1517.jpg[/attachment]
Drilling out the rivets and removing the brush holders
[attachment=8405]IMG00447-20110309-1545.jpg[/attachment]
I moved the brushes and insulation round and bolted them back in place. Wiring will be tricky as there is not much room in there. Before I go any further I am testing it. Here is the motor with the cross wiring done temporarily externally.
[attachment=8404]IMG00448-20110310-1003.jpg[/attachment]
Bingo. It works. we now have a starter motor that runs the right way, the gear engages with the idler gear on the CAT housing when it is slid into place. Motor spins up really well, no issues with the starter gear shaft in its new bearing. I made a small groove up inside and stuck loads of CV joint grease (molybdenum) in there.
Now just need to tidy up the wiring and get it inside the casing, make a lever for the idler gear slide mechanism, bolt it on and run it.
Nick
Fowler VF crawler
Sat, Mar 19, 2011 5:08 PM
