Gasket material
Gasket material
Showing 1 to 10 of 10 results
Pioneer1930
Send a private message to Pioneer1930
So what are you guys using for gasket material for your final drive cases? I made all of my gaskets for my pony and engine etc. except for the heads. I just tore down my final drives this weekend and have some bearings on order and I wanted to order gasket material but can't seem to find anything large enough or even that I could two piece together. Can someone point me in the right direction? Thanks for the help!
Mon, Mar 14, 2011 10:19 AM
Sasquatch
You could try your local NAPA store, they can get Fel-Pro bulk gasket material in rolls of varying thicknesses from 12"x12" up to 36" x 15 yds, might be around $150 for something that size though. You could also try industrial suppliers like Grainger, McMasterCarr, Applied Industries, etc. that may be cheaper yet.
I like to try to match the thickness of the old gaskets as closely as I can, I keep supplies of gasket material on hand from 1/64" thick up to 1/16" thick, and cork-rubber sheet from 1/16" thick to 1/8" thick. That pretty much covers everything I get into.
Mon, Mar 14, 2011 10:35 AM
Arborigine
Send a private message to Arborigine
Reply to Sasquatch:
Try a marine supply house in any major port city. I did a stint as a machinist in a shipyard and we had some HUGE gasket paper.
Mon, Mar 14, 2011 12:41 PM
kracked1
Reply to Arborigine:
The correct gaskets are no longer available? I have been very surprised at what Ziegler has on hand for gaskets yet.
Mon, Mar 14, 2011 7:14 PM
tanker
Send a private message to tanker
I will post 2nd time-- Go McMaster Carr- get "o" ring cord stock the right thickness- glue on 1 side of case [w crazy glue] w/ db; bead [ 1 twords inside & 1 tword ouside- fill in middle w/ Ultra blue {oil resistant silly seal- also from McMaster} and presto- a never leak gasket/ seal..👋
Mon, Mar 14, 2011 8:30 PM
tanker
Reply to tanker:
Mc Master Car #117 page 3387 pt # 7600A22 = 13 oz ctrg ultra blue $18.45- local napa has small tubes but more expensive-- ------ ------ page 3465 Buna N & neoprene "o" ring cord stock-- eggsample--3/32 buna n pt#9407k11 @ 0.24/ft 7neoprene 12975k32 @ 0.24/ft w/ discount @ 100 ft roll..-- I have cat but maybe it is possible to order on line??👍
Mon, Mar 14, 2011 9:35 PM
lots of aftermarket gaskets now come in "puzzle pieces". They fit together with joints so the pieces are mostly straight and not too long. I could see a special gasket punch being made to cut both sides of one of the joints.
Tue, Mar 15, 2011 2:06 AM
Thank you received: 22
I've had plenty of problems with those pieced together gaskets. They come apart at the joints so I make my own before I'll use them again.
Tue, Mar 15, 2011 3:10 AM
chriscokid
I agree with OM, it is easier to make your own out of one piece material than it is fooling with material that you have to joint together.
Tue, Mar 15, 2011 3:44 AM
Pioneer1930
Reply to chriscokid:
Thanks for all the input guys. I went ahead and ordered some large sheets from my local Napa guy. 36" square. I'm on the bus with OM I hate to have joints in my gaskets, not that they haven't worked for me in the past but as big as this job has been I would like a solid gasket to go along with all the work and money. Thanks! 👋
Tue, Mar 15, 2011 5:04 AM
rustrunner
Send a private message to rustrunner
Reply to Pioneer1930:
knoxvillerubbergasket.com
These people can supply you with any thickness of gasket material any length you want. I think all is 3' wide, Have purchased from them many times, I think they have good prices, but always pick up, and have never had anything shipped.
Tue, Mar 15, 2011 8:11 AM
