What specific work are you doing and what are the track link part numbers?
Hi Magnet
I am going to weld build up what is needed on rails rollers and sprockets.The rail links are 1s8841 dry 8 inch pitch. the rollers are 8h5373 assem. I was going to use 7018 build up and wearshield mm or abr. I need new rail hight and roller diameter.
Thanks shaper.👍
Make sure your comfortable , 12 hours per roller , 3-4 days per rail . Tim
Hi Magnet
Thanks shaper.👍
