Welding Cast Iron
Welding Cast Iron
Showing 1 to 10 of 40 results
gary ca
This is a progress report and request for advice on Ernie, a PV 15. We last left this restoration project with Ernie only running for 5 or 6 seconds before he would quit. It appeared that there was alot of smoke coming from the exhaust manifold other than out the outlet pipe. I decided to take apart the exhaust/intake/heatbox assembly to check for sealing of all surfaces. The main gasket looked tired but I did not notice any intake leaks on the two ports. The heat box gaskets were basically non existant and obviously not sealing. On the intake manifold, the sealing lip closest to the block for the heatbox, there was a slight depression from rust/wear and I think this is where the major leak is. It looks like this area should be welded to raise it up so I can get a flat surface. This depression is about .030 to .040 inches deep. My question today is on this thin lip, what is the best welding rod to fix this and how hot shoud the cast iron be preheated before the welding begins? Thanks again, Gary
Thu, Feb 17, 2011 8:53 AM
Arthropod
Send a private message to Arthropod
I have read a lot of positive talk regarding the Palco 808 rods. Palco states no preheat required with these rods.
http://www.palcoweldingsupply.com/808.html
I've welded cast a few times, but never preheated. Instead I tried the slow method, welding small sections at a time, with lots of cooling time between welds. The stuff I welded wasn't under any stress.
Thu, Feb 17, 2011 9:34 AM
u-joint
Send a private message to u-joint
Reply to Arthropod:
i like to weld cast with 7018AC. for an exhaust manifold you will need to use a nickel
rod for cast iron. used exhaust manifolds are difficult to weld, 7018 will not apply. the
only rod i have gotten to work is a cast nickel. luckly you are not in need of strenght.
heat to around 400/500 degrees and weld. weld an inch or so and take your chipping
hammer and peck the area you welded and the rest of the manifold for 30 seconds or
so. weld again and peck, weld again and peck. this works really well to relieve the
stresses that occur in the welding process. as the piece is cooling after you are done
welding continue to peck at the manifold untill it cools to a level you can lay your hand
on. let it cool naturally while pecking on occasion. if you do not peck, you may hear a
loud pop, that being a new crack. do not forget to grind or clean the area to be welded.
Thu, Feb 17, 2011 12:22 PM
ol Grump
Reply to u-joint:
The best electrode I've found for old cast iron is one made by Castolin Eutectic, Eutectrode 2-44 . Let's just say it's expensive!!! The second best is Ni Rod 99, but it isn't cheap either. The procedure I use when not preheating is to weld as cold as possible, no more than an inch at a time and then peen 'til cool enough to lay a hand on the weld. Another inch, peen and let cool, etc.
Ni Rod 66 is also available, a little cheaper than the 99 but it's not machinable, the 99 is. While a mild steel electrode like 7018 can be used on cast iron, it takes a lot of preheat, peening and slooow cooling to make it work.
Thu, Feb 17, 2011 9:40 PM
moonshadows
Send a private message to moonshadows
Reply to ol Grump:
all these answers are good but if you just need to build it up a little for better sealing just float a little braze on it then mill/ grind it back to where you need it less worries about cracking or melting your thin lip or if it is super thin i have even used silver solder to fill small gaps and cracks where strength is not important --- just my 2 cents --- scott
Thu, Feb 17, 2011 10:05 PM
dtcohen
Send a private message to dtcohen
Reply to moonshadows:
i would almost say to try something like JB weld or lab metal, for what you are dealing with i feel like either one of those would work fine
Fri, Feb 18, 2011 1:53 AM
SSsssteamer
Send a private message to SSsssteamer
Reply to dtcohen:
I have welded up exhaust manifolds and heat boxes before using my mig welder with mild steel wire. The same precautions apply. Clean the metal well first. When welding cold, don't let the manifold get any hotter than you can comfortably hold your hand on. Another problem about welding cast iron with mild steel wire is that the weld is not machineable after welding. The combination of cast iron and mild steel makes a weld as hard as cobalt steel. You can grind it down, but don't try putting machine tooling to it. Another thing is that mild steel oxidizes in the heat faster than the cast iron does. For a weld job that will last for years and years, mild steal will not take the heat of an exhaust manifold very well. It will rust out before the cast iron will.
Fri, Feb 18, 2011 10:47 AM
tanker
Send a private message to tanker
Reply to SSsssteamer:
On something like manifold I use railroad rod{ is cast iron in stick form] [may be hard to find these days] requires a good flux for welding problem cast-use torch same as brazing- but cast is easier to flow/ build/ shape while melted/ preheat & slow cool down.will machine & look like original iron..
Fri, Feb 18, 2011 11:03 AM
Fower VF
Send a private message to Fower VF
Reply to tanker:
I dont think I would risk welding it and cracking it. If the pits are only 30 or 40 thou deep then either filling it with soft braze and machining back or just machining it would be safer. The last manifold I had in this state I machined back with a planer. Easier to clamp the thing in a straight line and gently plane the thing back to square. Not only did I get the pits out but I got each branch back in line. The planer is a much more gentle and slower action on the work than a milling machine, and the thrust on the workpiece is all in one direction. Therefore clamping an awkward shaped workpiece like a manifold is much more straightforward.
Nick
[attachment=8248]IMAG0020.jpg[/attachment]
Cat D7 4T; Cat 951 A
Fowler VF crawler
Aveling Barford DX8 roller
Ransomes TS 69 hexatrac plough (2)
Ransomes mole plough
Fri, Feb 18, 2011 5:08 PM
Reply to Fower VF:
Nick
Thats old school technology! (I like it!) 👍 I would have suggested brazing and filing flat or flat board sanding. If I had access to a machine shop still, I would have surface ground it as there aren't many planer machines used anymore.
Nice Idea!
Jeff
Fri, Feb 18, 2011 7:08 PM
John from Fresno
Reply to drujinin:
Nice Idea!
Jeff
I am not sure that you would want to surface grind a gasket surface like that or a head. Usually they don't reccommed a finish like that. They want the part to grip the gasket. I have a Van Norman head surfacer. It that has a horizontal grinding wheel in the table and you just run the part back and forth over it to gradually grind it flat. It has a pretty coarse wheel and leaves a fairly smooth finish, but nothing like a surface grinder.
John
Fri, Feb 18, 2011 8:33 PM
