8R D8 Radiator gaskets
Showing 1 to 6 of 6 results
D6 Pete
Hello All, cant find parts book for the 8R D8,,, rebuilding a radiator for a D13000 Gen Set ,, has same as 8R D8 Radiator .. Top tank 2F 429 ,, bottom tank 4B 3002. Can somone please look for a part number for the gaskets for the tanks to core .. 2 the same looks like.. I will check if Cat dealer has new ones or will have to make them!.. Thanks for looking ,,, Willy i guess you might have a parts book with those tank numbers in !!??. Thanks again .... pete....
Sat, Feb 12, 2011 1:31 PM
chriscokid
a supplier will only give you a roll of narrow width material to make the gaskets, so you would have to butt joint them in the corners. What I did was purchase a large roll of mat. that would allow me to make the gasket as a whole At least that is what i did for an RD7 genset.
Sat, Feb 12, 2011 8:58 PM
dick
Send a private message to dick
Reply to chriscokid:
In8R book tank numbers are diferent than those you gave but core number is 2A1747 and pair of gaskets are number 2A1748.
Sat, Feb 12, 2011 9:47 PM
ruakina cat
Send a private message to ruakina cat
Reply to dick:
I have a parts book for the D13000 genset but will be 12 hours before I put my hands on it.
Sun, Feb 13, 2011 12:58 AM
tanker
Send a private message to tanker
I haven't bothered to buy such gaskets- I use Ultra blue - for pan gaskets etc I use "O" ring cord stock - crazy glued to block [for spacer]- use diam = thickness of original gasket]- 1 on inside of bolts & 1 outside w/ the silly seal between= no leaks & none of ultra blue gets pushed where you don't want it- tighten bolts till it just starts to ooze out a bit..
Sun, Feb 13, 2011 3:12 AM
Lance Jones
Reply to ruakina cat:
Hello Peter, If you need it I have a roll of 3ml Rubberized Cork 1 mtr wide for making Radiator Gaskets . Give Me a Cooee, and I could Bring it to the Sale next weekend. Be supprised if Hastings have them avaliable. Lance.
Sun, Feb 13, 2011 11:15 AM
D6 Pete
Reply to Lance Jones:
Thankyou Dick,, that is the right number ,2A1748....will try Cat dealer to morrow ,, if no good will call Lance for cork gasket,,.. Many Thanks ..Regards pete
Sun, Feb 13, 2011 4:21 PM
| Hartley - South Australia
