Undercarriage wear measurements for d4
Cat99
Send a private message to Cat99
Hello
I'm looking for a guide to measure undercarriage wear for a d47u. Is there an information sheet out there?
Thank You
Fri, Jan 21, 2011 12:57 PM
bruce oz
Thank you received: 19
http://www.tractorparts.com/undercarriage.htm
hello cat99 ,the link above shows you were to measure each part of the track gear and then we need the part number from each part to give you % worn ,bruce oz
Fri, Jan 21, 2011 1:41 PM
Reply to bruce oz:
Try this website also.
http://www.crawlerheaven.com/
Fri, Jan 21, 2011 9:04 PM
D4Jim
Thank you received: 12
Reply to dpendzic:
Here is a simple wear chart for the old Yellow critters.
Cats Forever
Sat, Jan 22, 2011 11:37 AM
Cat99
Reply to D4Jim:
Thanks a lot guys that helps a lot.
Sat, Jan 22, 2011 12:45 PM
