Rose bud torch question
Showing 1 to 10 of 14 results
XtremeXcavator
Send a private message to XtremeXcavator
My question is , why does a rose bud torch "pop" like a fire cracker? Ours will work good for 15min. then start poping and then eventualy go out. I was at my buddy's today and his would not stay lit and we never even got to use it. we cleaned it inside and out, and tried the oxy.& acyt. @7lbs.each and 10lbs.each and no diff. any sugestions? thanks, Jim
Thu, Jan 20, 2011 10:53 AM
Steve A
I know you are limited as to the size of tip you can use based on the size of the bottle, Acetylene is a liquid in the tank and is slow to vaporize, I believe the cold makes it worse. When the mixture gets to lean you get the POP
Thu, Jan 20, 2011 11:06 AM
Not the total answer, but keep an inch or so long cone of white flame in the center instead of increasing the oxygen until you get individual white cones on each hole. I think the one we used to have wasn't as bad to pop out as the one we have now.
Thu, Jan 20, 2011 12:22 PM
STEPHEN
Getting too hot is part of the problem, so 1) Use a more carburizing flame if you can.(slightly cooler flame) 2) Don't get the tip too close to the work as heat is reflected, don't hold at an 90 deg angle to the work 3) Use a larger tip at a lower setting(larger tips have better heat dissapation) 4) Sometimes it seems that more fuel pressure helps, I use at least 10 PSI. 5) Use two torches at a lower setting
Thu, Jan 20, 2011 2:35 PM
Reply to STEPHEN:
When I was in charge of maintaining the welding supplies at an engine manufacture, the issue of popping rosebuds torches came up quite often. Some could make them work, some guys couldn't. Finally I talked to the local Welding Gas supplier, did a little Googling and came up with the facts that where most guys set their oxy-acet torches for 6psi acet and 21psi oxy, this works fine for standard cutting and most, not all brazing applications (for this you can turn down the oxy).
BUT! When you put a rosebud on, you need to turn the Oxygen pressure up! If I had the chart handy, I believe the smallest rosebud requires 35psi oxygen.
Turn it up and try it again, see if it helps. The higher flow will help with cooling the tip which in turn should help with reducing the popping.
Jeff
Thu, Jan 20, 2011 8:34 PM
Painter
Send a private message to Painter
Reply to drujinin:
Jeff
Oxygen should be set at 5 times the pressure of the actelene, I run 7 psi actelene, to 35 psi oxygen. I get the popping when it gets too hot, with the tip too close to what I am heating. Usually back away a little and don't have the problem.
Hi, My name is Dennis, and I am a Rust-a-holic!
D4 7U17091 D6 8U10305 1926 Cat 30 1955 Ford T800, 74 Ford LT9000 1936 K Allis
Thu, Jan 20, 2011 9:05 PM
OldNuc
Send a private message to OldNuc
Reply to Painter:
Not all rosebuds are created equal. Dig up the manufacturers literature on the torch tip you have. Use the manufacturers recommended gas pressures for the tip size for best results.
The general rule of thumb of O2 5X Acetylene will get close for most of the common tips.
Thu, Jan 20, 2011 9:17 PM
jw45
Send a private message to jw45
Reply to OldNuc:
yes bottle size on act does make a difference the bottle is filled with white acetone powder act is put in bottle in gas form and is absorbed by the acetone takes about 24 hrs to fill bottle and bottle is filled under water to keep the bottle cool so the acetone can only release it so fast if your rose bud pulls to fast you can actually suck the acetone up into your torch acteylene is the most unstable gas thier is very explosive keep it safe never try to transfer it to another bottle
Thu, Jan 20, 2011 10:11 PM
nw4evr
Send a private message to nw4evr
Reply to jw45:
I have two rosebud tips,one has bigger gas holes and one has smaller holes, one pops, one does not, with the same regulator settings,,,
I agree with the previous posts, mainly, too hot, too close and incorrect/insufficient pressures... From my experience, if you get too close and tap the tip to what you are heating, it pops,,,,,,, sometimes a series of pops, sometimes it stops when you back away, sometimes not...But I know that it sure makes me jump!!!! I try to hold my ground and not be startled, but every time it gets me!!! Dave P
R2 5E 3542 SP, 22 2F, 22 1J
Thu, Jan 20, 2011 11:48 PM
oldparker
Send a private message to oldparker
Reply to nw4evr:
It is usually a good idea to have backflow preventers( check valves) installed on between the end of the hose and the torch. They should be used with any oxyacetylene equipment to prevent those pops and backfires from starting a fire in the hoses. Even with a cutting torch, if she pops and then makes a strange whistling sound, shut it down as fast as you can, because the inside of the torch body is burning. Very bad!! Like everyone above has said, getting the tip too hot will cause this with the rosebud, and while using a cutting torch on dirty or rusty metal, you can get pops when the rust scabs jump off the material you're cutting and hit the end of the torch. Good reason to clean the metal with a grinder before cutting. You'll get a much better job faster and safer.
Fri, Jan 21, 2011 2:55 AM
cowboyofequipment
Send a private message to cowboyofequipment
Reply to oldparker:
Try two acetylene tanks and regulators with a Y-fitting after regulator. This will stop the popping and cracking as it is the fuel gas that cools the tip. You could also try propane as it is much more stable gas. This will require a new rosebud tip.
Fri, Jan 21, 2011 8:57 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
