D24U Low Oil Pressure - gauge check
Showing 1 to 6 of 6 results
mcclaar
Send a private message to mcclaar
While I'm doing the steering clutches on my D2 I thought I would look into the low oil pressure problem. When the oil is cold I have great pressure but once the engine has ran for a while it seems to drop. Easiest thing to check would be the gauge itself and it looks like its good.
Is there anything else I should check? I still need to look at the pump pickup screen, and the relief valve and spring. Is this a common problem with a D2? I'm hoping the main/rod bearings are okay.
D2 4U-2045
Tue, Jan 18, 2011 10:57 PM
Arthropod
Send a private message to Arthropod
I would think if the screen is clogged, the pressure would be low from the start. One of my D2s pressure is low at idle after it gets hot, but stays well into the safe range when at higher RPMs. Oil pressure comes from the mains, so I guess worse case she's wearing out. Wouldn't hurt though to check the screen, oil filter and such, just to make sure. If you drained the oil, I wonder if you could use a sight mirror accessing through the side plates and see the screen. Rather than dropping the pan. If you remove the pan, might as well pull a couple of main caps and plasti-guage to see the clearances.
Tue, Jan 18, 2011 11:51 PM
Reply to Arthropod:
I was under the assumption that the oil pump pickup screen could be serviced thru the side plate on the oil pan? Haven't done that yet but that is my plan! :noidea:
Wed, Jan 19, 2011 2:47 AM
Arthropod
Reply to dpendzic:
I've never done it either. I just happened to have the side plates off my machine this past weekend so I could look at the bottom of the cylinders (inspecting my stuck pistons) and I realize that you can see a lot with those two plates off. I can see some signs of rust at the base of one of the two pistons that are fully down. I suspect that guy is the main reason the engine is stuck.
Wed, Jan 19, 2011 3:56 AM
Thank you received: 27
Reply to Arthropod:
here is a scan about the pressures expected at the start and finish of the White Operating Range of the oil pressure gauges used at the time.
This should set macclar's mind at rest.
Wed, Jan 19, 2011 9:08 AM
Sasquatch
Thank you received: 5
Reply to edb:
I have always been told that these engines have a rather high volume lubricating system, and lower pressures on the gauge are not necessarily detrimental to the safe operation of the engine.
Here is a quote from my 5U D2 operator's manual-
"OIL PRESSURE GAUGE: Immediately after the engine has started, check the crankcase lubricating oil pressure gauge to see that it is registering pressure. When the engine is running at rated engine speed the gauge should register in the "Operating Range". A lower pressure reading is normal at low idling speeds. If no pressure is indicated, investigate at once."
Wed, Jan 19, 2011 9:53 AM
mcclaar
Reply to Sasquatch:
Eddie B. and all,
Thanks for the information guys.
Andy
D2 4U-2045
Thu, Jan 20, 2011 1:00 AM
