track roller replacement
jbeam
Send a private message to jbeam
I just put new tracks on the dozer, sprockets and idlers are almost new, I replaced 2 bottom rollers the rest of the bottom rollers look okay (around 40/50%) will I be hurting the new rails by running them over rollers that arent all the same exact height, should all of the rollers be replaced at the same time, or can I wear out the remaining rollers that still have life remaining, thanks jbeam
Sun, Jan 16, 2011 10:06 PM
D4Jim
Thank you received: 16
Hi jbeam,
My opinion is that all the rollers should be the same unless one is just getting by for a short time. If the rest of the tracks are new, I would make it all new and replace all the rollers.
I have a 4 roller D-4 7U and I started with replacing the two front and the two back rollers and leaving the two used middle rollers on each side. It rode like a piece of crap. I would not have believed that little difference in the middle rollers would make that much difference. I replaced all the rollers three weeks later. In my opinion, replace them all or rebuild all at the same time.
Cats Forever
Mon, Jan 17, 2011 4:38 AM
Reply to D4Jim:
Hi jbeam,
I just replace the back two or the front two when they get warn. I have not noticed any difference in the ride. If you replace the middle two in the long run you will be throwing 50% life of the rollers away. I generally replace the front or rear two and build back up the middle rollers along with the carrier roller.
Mon, Jan 17, 2011 6:22 AM
bob
Send a private message to bob
Reply to dpendzic:
It's advisable to have all rollers as close as possable to the same size. I recomend replacing a lost roller with a good used one of as close to the size of the others as you can get. A new full size one will run hard under the machine and wear fast. Undercarrage parts all work together and wear together.
Later Bob
Mon, Jan 17, 2011 9:40 AM
