D2 - Stuck diesel - suggestions to get her turning
Showing 1 to 10 of 27 results
Arthropod
Send a private message to Arthropod
So my latest addition to the flock is a D2-5U s/n 10502. Complete machine with CAT blade, except missing some minor pieces. Pony is free. Diesel is stuck. I had posted earlier about the magneto, but still haven't remembered to write down the mag's part number. I think I have the mag back together correctly. It sparks. Haven't tried to start the pony yet. Want to get the diesel free.
So, what methods have people used to free a stuck diesel? I don't know its history. It's probably been stuck a while, but it looks like maybe because someone had the breather off the intake. The stack was covered. So, about a week ago when I obtained the machine I squirted various fluids into each cylinder. AT fluid, some PB Blaster and also some Deep Creep. I have put a bar inside the clutch housing and pried lightly on the clutch to see if the flywheel will turn. It doesn't...yet. So, short of removing the head, any suggestions on how to attack this problem? I don't mind removing the head if that is the best way to go. My main problem is figuring out where to apply pressure to see if the engine will turn.
Thanks.
Sat, Jan 8, 2011 2:15 AM
zootownjeepguy
My D2 was stuck when I got it too. Although the exhaust was covered and the whole machine had a tarp over it, water still found it's way into #2 & #3 cylinders (not anti-freeze luckily). That water also helped all the valves & seats rust away to the point that the head needed a major ($$$$$) rebuild. I know it's a lot of extra work but I would recommend pulling the head, just to see what's going on in there. It's also good to check the condition of the cylinder walls and valves while you're at it. Another good reason for pulling the head off a stuck engine is so you can apply pressure directly to the top of the pistons, if (hopefully) the crank is NOT at top dead center. I made a strap out of some channel iron that bolted onto a couple head studs and I put a wooden block on top of one cylinder and a small bottle jack between the channel iron & wooden block. Worked great, but put the fire out first (see below)!
If you're pulling the head, a little fire is probably the best method for "unstucking" an engine. Put some Diesel or ATF in each cylinder and a little gasoline and light a fire in each cylinder. Let it burn for a half hour or so and that'll heat up the cylinders and really help loosen the engine.
Good luck, and hopefully yours won't be as bad as mine.👍
Rich Salvaggio
D2 5U9917
Sat, Jan 8, 2011 6:39 AM
Bill Glenn
Arthropod,
I don’t think there is ever a straight / clear answer for that question.
I’ll give you a (my) short story on this… My D2 was stuck when I got it also.
The main clutch was stuck also.
I separated / hoisted the diesel from the bell housing to fix the clutch.
While I had the diesel separated from the rest of the tractor - I made up this 10ft long bar – with lugs that fit into the flywheel teeth.
That way I could really pull on it and not have to worry about harming anything.
I did get it to move – and then turn. But it was pretty “crunchy”.
I did eventually take the head off – and when I did I found LOTS of rust & crud.
I don’t know how rusty these things can get and still run OK after being broken free.
I can’t imagine I would ever have had a decent running machine in that condition - had I tried to start it.
The rings were even rusted fast in the ring grooves.
If yours is stuck and you managed to free it up externally without a lot of trouble – I would say go ahead and try and start it.
Otherwise tear it down.
Bill Glenn
Sat, Jan 8, 2011 7:04 AM
deetwocat
Send a private message to deetwocat
Reply to Bill Glenn:
Arthropod,
Bill Glenn
It has been for me at least the best bet to take the head off then you will be able to see whitch cylinder is stuck also get some diesel oil on top of all pistions in the morning if some cylinder stills have oil on top that is the stuck cylinder plus the rings probaly stuck to pistion.some guys swear by coke cola never had any luck with it but taste better than diesel.
Sat, Jan 8, 2011 7:52 AM
Reply to deetwocat:
The only one I never had to pull the head off from was "Flash Rusted", it ran and did an OK job for its purpose but eventually the compression got worse and harder to start. I pull heads, that way you can check the condition of all the parts that will wreck the engine if they are in poor condition and fail. (drop a valve while running and see who destroys what!)
Sat, Jan 8, 2011 7:55 PM
ol Grump
Reply to drujinin:
I've freed up several "frozen" engines by pulling the head and finding out which cylinder was rusted up, then pouring in several ounces of diesel, tossing in a small rag and lighting it. After it's burned all the diesel, let the piston cool to body temp and put a block of wood slightly smaller than the bore on top of the piston and whacking it gently 😆with a 12 lb molecular realignment instrument, also called a beater.
As soon as there's movement, I start turning the crank to get the piston down a ways and use a flap wheel to get most of the rust off the cylinder walls and clean the crud out. I use a mix of either acetone and two stroke oil or Coleman fuel and two stroke oil as a "loose juice" and start turning the engine over by hand. If the heat and cool cycle doesn't work the first time, try again.
Sat, Jan 8, 2011 10:27 PM
Thank you received: 23
Reply to ol Grump:
Ol Grump - what's a flap wheel (and do you have a photo)? I might need to do the same to my D2
Neil.
Sun, Jan 9, 2011 7:29 AM
Neil.
is a mandrel with short strips of sandpaper attached to it for use on a power drill. I see them all the time in the wood finishing area of your local Home Depot.
Jeff
Sun, Jan 9, 2011 7:33 AM
ol Grump
Reply to drujinin:
Jeff
http://www.3m.com/product/information/coated-abrasive-flap-pg-wheel.html
There are the ones I use. .I'd guess the ones for wood would work too but as I'm not a sliver picker😆 I use the ones for metal. 80 grit seems to work well without getting too loaded up.
Sun, Jan 9, 2011 9:25 PM
64farmboy
Reply to ol Grump:
I welded up a cradle out of square tubing attaching it to the head bolts, machined an aluminum plug to 3.950 diameter and put light pressure on the piston with a small bottle jack, filled the cylinders with some PB and marvel mystery oil. I let it soak and kept adding a little pressure and it broke lose. I then took my cylinder hone with progressively finer stone and cleaned the bores up. I ended up pulling the pan, changing the rings as well and having the head rebuilt with Cat valves. I'm glad I did the rings as when I pulled the pistons I had stuck and broken rings.
Dennie
Sun, Jan 9, 2011 10:24 PM
ferraridoctor
Send a private message to ferraridoctor
Reply to 64farmboy:
Dennie
The reason you mite use Coca Cola to loosen the pistons is because it has phosphoric acid in it to keep the carbonation from going flat. Google Phosphoric Acid and you will find that it is used as a rust remover/converter. We use it in the automotive industry to remove rust from parts before painting. It will change the rust to a black phosphate coating that can be removed or left to prevent further rusting. Using it in an engine will work to breakup the rust in the cylinders and around the rings but it can not be left for an extended period of time because being an acid it will keep eating on the cylinder walls until they are damaged. I remember in High School Science class we put a large nail in a bottle of Coca Cola and a few weeks later it was gone.
Chuck
Mon, Jan 10, 2011 1:00 AM
