D4400 manifold flamethrower
Showing 1 to 10 of 13 results
snowshoveler
Send a private message to snowshoveler
Hi guys its me again...
I've been working on the powerunit quite a bit as im on vacation.
Worked at the flamethrower do-dad that's in the intake manifold.
I would like to get it working so the little guy starts with out getting hooked
on the either bunny.
I dont think it was being used the last times the engine was running,so the wireing was missing.
Any idea if this thing uses 12 or 24 volts,I looked at the coil that generates the spark but it has no visable markings.
I wired it up with the start solinoid because there is a warning to only use it when engine is cranking.
I would think that I would roll the engine with the fuel rack in the off position and pump the handle. As pressure is built in the line and this trips a switch which allows the coil to generate a spark at the sparker.
This should ignite the fuel mist in the manifold on its way to the cylinders.
With some heat in the cylinders the throttle would be advanced and it should start right up.
Sounds awesome on paper...does it work.
Aint got a clue,but im getting there.
Not sure how long to use it when attempting start.
And just because im curious,whats this things proper name.
Thanks again your faithfull reader Chris
193? d4400 cat powerunit
1950 john deere M
1959 international t5 crawler
1977 powerking 1216 tractor
Fri, Dec 31, 2010 5:53 AM
Thank you received: 19
Yes, when they are tuned up they work well. Just called a Manifold Heater.
These scans should answer your questions.
Where's the pics????????
Fri, Dec 31, 2010 8:22 AM
snowshoveler
Old Magnet...
Once again you step up and help the new guy.
Thank you very much.
I think I would drive a long way to buy you a beer and shake your hand.
Pictures will be along as soon as I get the Missus to help with them.
3 very nice cameras here and im not qualified for any of them.
I do well to read and write and turn wrenches.
Chris
1950 john deere M
Fri, Dec 31, 2010 8:34 AM
tyoos
Send a private message to tyoos
Reply to snowshoveler:
Old Magnet...
Chris
I'd love to see pictures of your manifold heater. I've seen the parts diagram in my
brother's D4 5T parts book and I have liked the set up ever since. I'd really love to find
this setup for my D4400 power unit. If you need to see the parts diagram out my brother's
book let me know and I'll scan it for you.
Thanks, Josh
1954 Cat D4 7U28304SP with cat angle dozer and Hyster D4N winch
1954 Cat D4 7U28174SP with cat HT4 lodaer
1953 Cat D4 6U with cat bulldozer
1946 Cat D2 5J8424SP with Traxson T2 loader 624 and canopy
1954 Cat D311 4V6821 Gen Set
1946 Cat D4400 1S4444 Power Unit
1959 Mack B421 semi tractor with 413 Chyrsler engine
International R190
1939 International D2 pickup truck
Lei Roi Tractair aircompresor
Clark airport luggage truck
1947 Farmall A
1946-1977 20 Gravely Lawn and Garden Tractors
Sun, Jan 2, 2011 1:34 AM
railroadjoe220
Send a private message to railroadjoe220
Old Magnet...
Chris
Where can you buy the heater? My neighor was telling me that the Oliver tractors of the 1970s used a air intake heater,would this work on a d47j.
Thanks Joe
Sun, Jan 2, 2011 1:44 AM
Lance Jones
Reply to railroadjoe220:
Thanks Joe
I am not familiar with the Cat Manifold heater on the 4400 ,but I have had a bit to do with Perkins manifold heaters . The P3 and P6 motors made in the early 50's used them and they are available as a repro on UK Ebay , under " Fordson Tractor " The P6 motor has a small hand pump that sprays fuel onto the heater coil , they worked Well. LJ
Sun, Jan 2, 2011 2:50 AM
there is a version available today called a Thermostart. Used on Ford, Perkins, Yanmar and other diesels. A search on "thermostart" will get some hits to show about these. They would only be useful on tractors with a battery as opposed to the CAT design using the magneto to ignite the fuel.
Sun, Jan 2, 2011 9:30 AM
Cat had both battery and magneto fired heaters. Check my earlier post on instructions.
Sun, Jan 2, 2011 10:59 AM
snowshoveler
Have some pictures ,I think.
1950 john deere M
Sun, Jan 2, 2011 10:44 PM
tyoos
Chris,
Here's the pictures. Keep in mind that these diagrms are for a D4 with the D4400
engine and this set up runs off the pony motor magneto.
Hope it helps, Josh
International R190
1947 Farmall A
Thu, Jan 20, 2011 4:10 AM
snowshoveler
Reply to tyoos:
Chris,
Hope it helps, Josh
oops...sorry no pics.
can you try again,please please ,pretty please.
thanks Chris
1950 john deere M
Thu, Jan 20, 2011 4:44 AM
Price Tractor Pull
Price Tractor Pull
