soda blasting
soda blasting
Showing 1 to 10 of 15 results
Jeff Chattin
Send a private message to Jeff Chattin
Has anyone had any experience soda blating a tractor? I want to paint my D7 and wondered if this would be the route to go. Thanks Jeff
Fri, Apr 27, 2007 7:56 PM
B4D2
I know one of the guys at Chicago Streets and Sanitation, and they soda blast the salt trucks when they re-paint. He say's it works really well, and it is alot easier on the metal.
Fri, Apr 27, 2007 8:30 PM
D2Redsetter
Send a private message to D2Redsetter
Reply to B4D2:
I saw a machine that was soda blasted and repainted and looked good.
Will probably have a D2 done this summer.
Fri, Apr 27, 2007 8:35 PM
D2Redsetter
Reply to B4D2:
Saw a machine that was sodablasted and looked good.
Fri, Apr 27, 2007 8:38 PM
gwhdiesel75
Reply to D2Redsetter:
What is "soda"? I know about sand and glass beads, but soda? GWH
Fri, Apr 27, 2007 8:39 PM
WyoCat
Reply to gwhdiesel75:
I have done a little soda blasting. We used baking soda as the media. This very fine media works good at removing the normal stuff but it biggest benefit is that it helps nuetralize the active oxidation in the rust. Since it is not as abrasive it can take a bit longer in certain areas on some types of hardened paints. There are a lot of different types of media blasting, plastic beads, ceramic beads, aluminum oxide and I have even heard of using talc on aluminum materials. Hope this helps.
Chad Enyeart
Fri, Apr 27, 2007 8:49 PM
WyoCat
I would try aluminum oxide. It comes out with a bright crystaline finish.
Chad Enyeart
Sat, Apr 28, 2007 2:57 AM
biggastractor
Reply to WyoCat:
Soda blasting is getting popular here in Minnesota. Lots of marina's use it to clean below the waterline on fiberglass boats. It doesn't have the potenial to ruin the soft fiberglass like sand blasting does. I understand that sodablasting a piece of steel can almost be done in layers Some advertise taking the paint off of a seafoam can without hurting the can. It can be controlled closely and is therefore used in antique and classic car restoration. I had a quote to sodablast my 60 for $750.00. Once the sodablasting is done I have heard that you have 4-5 days to paint before rust is an issue. This is unlike sand blasting where you have a matter of hours.
The bad news is that you must pressure every tiny particle of soda off the tractor or it will react with the paint and you will have a very poor paint job.
Good Luck
Biggastractor
Sat, Apr 28, 2007 7:59 AM
Delta Dirt
Send a private message to Delta Dirt
Reply to biggastractor:
Good Luck
Biggastractor
I'm in the same boat as GWH on the soda----are you talking about a product like baking soda?
How do you apply it?? Dry with an airblaster system----or, possibly wet via a pressure washer?
Give the uneducated more "basic" information----never heard of it before.
Thanks--
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
Sat, Apr 28, 2007 10:24 AM
B4D2
Reply to Delta Dirt:
Thanks--
Delta Dirt
I beleive the baking soda is blasted wet with a hi pressure stream of water/soda mix. I have actually added baking soda to wall paint on request by a client because they were allergic to the chemicals in latex paint. The baking soda absorbed the offensive odors and it didn't cause too much of a change in the paint texture.
Sat, Apr 28, 2007 9:57 PM
Reply to B4D2:
I would have to see baking soda blasted wet to believe it. I am sure it is another type of dry blasting media. Several years ago (maybe more than several) feed grade bicarb was around $250/ton in 50# bags. Might be fairly cheap compared to other blasting media?
Sun, Apr 29, 2007 8:42 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
