1956 Cat D2 5U wiring diagram
Cysco
Does anyone have a wiring diagram for a 1956 Cat D2 5U with headlights, switch, ampmeter and pony starter. It is a Delco 6 volt, 18amp generator. The generator checked out fine and the lights I bought were 6 volts so I'll use them till there are problems and then swap to 12 volts.
Being "cost effective" for now.
Thanks....Bill
Wed, Dec 8, 2010 8:47 AM
This should do it...
Wed, Dec 8, 2010 9:49 AM
Cysco
Thanks Old Magnet !! That is what I needed. I hope to have everything together in the next few days. I got the carb done and back on the manifold. I was having some suspicions about the governor spring on the pony so I ordered a new one of those as well.
Gotta like these winter projects !
Have a good evening.......Bill
Wed, Dec 8, 2010 10:42 AM
lrolla
Send a private message to lrolla
Reply to Cysco:
Does anybody have the switch part number for this configuration? i need to find a light switch that mounts in the battery box.
Thanks, Larry
Larry Rolla
Wed, Dec 8, 2010 1:03 PM
Reply to lrolla:
Thanks, Larry
The original light switch is a 7F2921.....more commonly mounted in the dash.
Wed, Dec 8, 2010 11:16 PM
Dozerman51
Machinery Trader shows some vendors that have some. Go to the site and scroll down to "Machinery parts for sale", click on that and punch the part number in the box. Hope this helps.
Wed, Dec 8, 2010 11:43 PM
Dozerman51
Thu, Dec 9, 2010 12:09 AM
Cysco
Reply to Dozerman51:
Don't forget the circuit breaker.
Thu, Dec 9, 2010 7:02 AM
Cysco
Reply to Cysco:
Well I got most everything rounded up now. Found an NOS Cat/Delco voltage regulator. I have working Guide lights ( bought them from d4Harry). Found a pair of light brackets, new switch,original amp gauge and Old Magnets wiring diagram. I do have one question though. In the attached picture of the hood the two holes for the light wires to pass through are not quite far enough back to miss the radiator. Is this the norm? I have the grommets already installed but wonder if they will raise the hood to high.
Any thoughts would be most helpful.......Bill
Sun, Dec 12, 2010 11:28 AM
